Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
My phone says miximum limit of applications reached
It comes up when I try to do anything! I have deleted much of the stuff I had (pics etc) but I don't know what it wants me to do!! Help!
My phone keeps saying not enough space in device to for certain things. I want to delete all old messages etc. But I want to save my pics.
transfer all your stuff to a flash drive n than delete
other wise the memory problem will be solved by deleting some of ur applications
delete those which u dont use u dont have to delete ur pics though
Aug 31, 2016 | Samsung GALAXY S4
My phone writes insufficient memory how can i troubleshoot this problem
This means that the memory on your phone has reached its limit. Try moving your files to the computer (only stuff like pics and videos) and clear the memory. By doing this you will also make your phone run faster. :)
Jun 01, 2012 | Cell Phones
When I try to open a message my phone says maximum limit of applications reached. And I am unable4 to open the message?
some application is open and wasn't able to close it properly,close all unused application.
you might have to many message stored on your inbox,outbox etc. try to delete some so you might get into it.
also delete other stuff if you think you don;t need it anymore to save free space in memory and run smoothly.
if the above solution doesn't work,reset your phone by going to settings > master reset and everything wioll be in default settings,if ask for the code,just enter 0000 or enter your desire code if you change it before. Be sure to back up all of your data before proceeding,cause everything will be erased.
good luck.
Jun 16, 2011 | LG Cell Phones
Every time i try to send text or anything this appears" maximum limit of applications reached" I have deleted all photo's and videos and it tells me I am only using 5% space. how do i fix...
May be it means you have reached the maximum limit of the characters in a message. For that you need to go to your message options and change the settings to maximum limit for text messages.
Jan 24, 2011 | LG KC910 Renoir Cell Phone
When i open my gallery and my stuff the display show the message "maximum limit of application reached"
Try this...
Shutdown your phone;
Get the sd card out,restart the phone,shutdown again,put the card in ,and restart again.
I believe this message will not show again.("maximum limit of application reached").
Nov 25, 2010 | LG GD510 Cell Phone
When trying to send texts from my nokia E63 I get the repeated message Memory full close some applications then try again. Everything is closed and I have deleted everything off my phone!!
I realize that you stated, " I have deleted everything off my phone".
This includes both incoming and out going messages, texts, voicemail, etc? Any pix take up a bit of space too.
I'm just exploring the possibilities.
Best regards,
Mike
Feb 02, 2010 | Nokia E63 Cell Phone
Maximum limit applications reached ( LG cookies)
When you see that push the middle button. then tap the purple arrow in the top right corner and hit end all. I'm still trying to figure out a way to to allow more applications. But it's certainly better than having to turn your phone off. hope this helped it's my first comment :^)
Jul 31, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
MY LG KP501 says 'Maximum limit of application reached' help!
Click the middle button and the arrow that says Running application and press "End all"..
I hope that helped ^___^
May 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How to delete pics previously used as wallpaper? LG Chocolate
Go to MY STUFF, then IMAGES, find the wall paper you desire to delete and delete it. It will be deleted too, in MY FOLDER. It works for me, hope it works for you too.
Feb 16, 2009 | LG KG800 Cellular Phone
Fone memory full
hi my name is jasminder
hi have also nokia 6110 navigator
you need a file explorer for this delete the extra stuff using this software
thanks don't for get to rate
Jan 26, 2009 | Nokia 6110 Cellular Phone
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
