Question about LG Televison & Video
My Lg tv is not working, i have sound but not image, i only get stripes of diferent colors, I try to play DVD and the screen stil the same
    Top Expert:
  • LG Master
  • 79,865 Answers
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
I have a Plasma TV LG model # 42PC1DA. We have perfect sound, but no picture. Tried the contrast, tried unplugging for 30 min. What could be the problem and how much might it cost to fix it?
Did you tried diferent sources from where you get the image? For example you could try to connect a video camera, laptop, dvd or any other thing you could hook it up in your TV and check if there is still no picture.
If the screen is burned it costs the same or a bit less than a new one
Good luck
May 06, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Samsung rts-he10 sound
shown, from the DVD the if you are trying to the and image from the DVD to the TV goes conected on the output, and to the TV In the input. the color dont make a diference as long as what ever color you have is on the same output - input meaning
R Output - R Input
L Output - L Input
Jan 08, 2009 | Televison & Video
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Computer Repairing
Computer Repairing
