Question about Pioneer Audio Players & Recorders
To connect a eq to pioneer model surround receveir model vsx-9700s
5 Suggested Answers
emissionwiz
  • 75744 Answers
SOURCE: can harmen /karden eq ,eq8 be used with pioneer surround vsx-9700s
I don't see why not.
Posted on Nov 29, 2016
AndrexT
  • 14790 Answers
SOURCE: what does the word simulated mean when you press the button on the pioneer surround model vsx-9700s ,because i can use my eq . then
It phases the stereo by a few milliseconds so you get the real sound and then the same sound a few milliseconds later. It gives the effect of a sort of echo, to give spatial awareness to your brain to trick it to think you are in a big venue.
You say in another post you have distortion. You need to test with different speakers, or swap the left to the right and see if the distortion follow? It may also be that a component on the particular feature is faulty and need replacing, ab IC or capacitor.
emissionwiz
  • 75744 Answers
SOURCE: what does the button mean on this model mean simulated surround ,pioneer model vsx-9700s
It means that it takes a normal sound signal and turns it into surround sound.
emissionwiz
  • 75744 Answers
SOURCE: can you also press the button on the pioneer model vsx-9700s dolby surround and also make the harmen/kardon model eq8 function together
No they have different remote codes.
Posted on Dec 05, 2016
What does the button mean on this model mean simulated surround ,pioneer model vsx-9700s
Nov 29, 2016 | Audio Players & Recorders
What does the word simulated mean when you press the button on the pioneer surround model vsx-9700s ,because i can use my eq . then
Nov 29, 2016 | Pioneer Audio Players & Recorders
Im having trouble hooking up my equalizer to my Pioneer audio/video multichannel receiver vsx-814
Looking at the back..bottom right corner is CDR/Tape in and out. Connect the in on the eq to the out of CDR/tape, connect the out of the eq to the in of CDR/tape.
You should then be able to use the CDR/tape monitor button to switch the equalizer in and out.
Sep 25, 2014 | Pioneer Audio Players & Recorders
Connect pioneer vsx-9700s receiver to tech.equalizer??
If there is no rca connection on the back labeled something like "external processor" then it could probably go through a tape loop. At least that's the way it used to be done last millenia. ;)
Jan 18, 2013 | Bose 901 VI Main / Stereo Speaker
How do i connect a subwoofer to my vsx-9700s
on the back of the pioneer, you have a subwoofer preamp output jack, probably colored black, as opposed to red or white. stretch a rca cord between there and the red and white (or lfe) input of the sub. youll then have to check the amp setup menu and make sure it has the output activated. good luck
Feb 11, 2010 | Audio Players & Recorders
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
SPEAKER CONNECTION
problem with connection
Jan 07, 2008 | Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
27 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
