Question about HP OfficeJet 7410 All-In-One InkJet Printer
Hello! I have an HP officejet 7410. I took apart all the spares under the right side (where the inks are placed). Is there any type of instructions available to put it back together :-) ? Thank you!
  • yadayada
    yadayada Dec 05, 2016
    Not here.
  • rosp rospi
    rosp rospi Dec 05, 2016
    Thank you for the answear!
Buy an Epson
Posted on Jul 26, 2007
  • 10 Answers
SOURCE: ink cartridge carriage HP 7410
HP has extended the warranty for some of these printers like the 7410. It's worth giving them a call. They just replaced mine without charge.
Have your serial number ready when you call HP. (800) 474-6836
Tell them you have a "broken carriage shute and print cartridge rejection".
Posted on May 11, 2008
  • 623 Answers
SOURCE: Service Manual for HP OfficeJet 7410
For parts go here:
Posted on Dec 18, 2008
SOURCE: My hp officejet 4315 all in one says Cartridge
I replaced both cartriges bought at cartrige world. Screen on printer says: "Cartridge Error". I reinstalled both cartridges and still get "cartridge error". I don't have a owners manual, Help!
Posted on Aug 06, 2010
  • 41 Answers
SOURCE: 0x61011beb ink system failure on
1. Plug it directly into the wall, rather than into a UPS
2. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
3. Wait 30 seconds.
4. Plug in the power cable to All-in-One and also to wall outlet.
5. Check for the functionality.
I still had the error message, so they said to reset the printer to factory default settings:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
If those two steps do not resolve the problem then its is hardware related and can't be solved here.
Posted on Mar 23, 2011
Testimonial: "You are awesome!!! THANKS!!!"
Why does my hp 7410 all in one ask me to remove and check color cartridge?
Yeah, as I am a victim to this very same problem, the other guys are right. The metal spring that is part of the ink carriage becomes a hole punch for the ribbon cable right behind the unit. Now you have a useless printer that you think has faulty ink cartridges, but in fact it's a faulty printer. Because of this design flaw, HP should compensate each and everyone of us, no matter how long ago the purchase of the printer was. I bought mine in 2006 for over $600 and for such a little thing that will break at some point, causes such a huge problem. It's caused by you putting the ink cartridges into the unit. You don't have to be aggressive with the install for the failure to occur, normal installs will cause the same affect. My suggestion to you my friend is to put it up for auction on eBay and use that money for a new printer. Gots me a HP OfficeJet Pro 8600 Plus that was 1/3 the cost of the 7410, with pretty much the same features and more!
Jun 06, 2014 | HP OfficeJet 7410 All-In-One InkJet...
I have an HP Officejet 6210 All-in-one. The
1st check the ink spare is for your printer, then take the protective cover out (ink cartridge), check for any stucked/broken plastics. if all is ok, send printer to repair to check.
Dec 28, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Replacement instructions for ink cartridge carriage assembly
Please follow the link below to HP Web site. This will take you to the HP 7410 Setup Chart. The cartridge instructions you need begin in frame 10.
Oct 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410
Modem is part of the main board. Main board will have to be replaced. We have a few spares laying around.
866-381-054 1
Apr 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410
When you find out Jeff, I sure need to know too! Here's my story:
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place.
Mar 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Problems printing photos with HP Officejet 7410
copy and paste the link below into your address bar.
you can search for other answers at the top of the page.
Nov 22, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OFFICEJET 7410 "NO SCAN OPTION" the HP Director/Solution Center on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
Jan 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
