Question about GE GSS25TGPWW / GSS25TGPCC Side by Side Refrigerator
I have a GE gss25tgp, I was hearing noises earlier now i just went back to the fridge and now the water dispenser and ice dispenser aren't working would that be a control board issue?
    Problem Solver:
  • 10 Answers
The dispenser control board is fed from the main control board located in the back. The main control is usually the root of most problems .Order from repair clinic if it does'nt work they will take it back.
Posted on Dec 08, 2016
catriver
  • 878 Answers
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Posted on Jul 24, 2006
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
abhishek33
  • 1239 Answers
SOURCE: Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Posted on Jul 01, 2009
SOURCE: Fridge Makes Cubes But No Water
Get part number WR49X10173 from Consumer Relations (800-386-1215. (Free; be sure they understand how long you have had to deal with this issue) ($38+ if you buy part on line)
The part includes instructions to install, but not how to remove the control panel. Here's how: Look from below the panel to observe 3 holes (aprox. 1/8" dia) located in a long narrow depression. Observe that there is the edged of a plactic tab visible partly covering each hole. Use a pointed tool such as a shish-kabob skewer to carefully probe the hole at the right or left end, and carefully pull the control panel forward on the side with the hole you are probing. This will help release the tab, allowing the panel to come off. Repeat for the opposite side.
The instructions with the part take over from here. The part is a loop of wire that provides a bit of heat to keep the area warm, and is held in place by some aluminum tape, then spliced into the red and the black/white wires on the 6-wire harness on the left side of the control. BE SURE the power is OFF!!!!
Posted on Dec 26, 2009
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Dec 13, 2008 | Refrigerators
GE side by side fridge/freezer. Water stopped comming out the dispenser..
Hello.
If your frig only has a dispenser for water, the first thing you need to check, is the shut off valve, which is sometimes under the kitchen sink, and make sure nobody turned it off for some reason.
If you have a frig that dispenses both ice and water, and only the ice is working but you aren’t getting any water, then it is probably the water side of the dual water valve that has gone out. A lot of times the water side of the valve will go out before the icemaker side, because it tends to be on longer due to people filling up glasses and pitchers.
If you hear water running when you try and get water, then you probably have a leak in the water line that goes to the dispenser.
Another thing that is rare is the water will freeze in the reservoir that is behind the crisper drawers in the fresh food compartment. This sometimes happens when it isn’t used enough.
Nov 30, 2008 | GE GSS22JFMWW Side by Side Refrigerator
GE TFX20JR Have ice but no water
you have a duel water supply valve on the back bottom of frig.,the water dispenser side might be bad,or you have a micro switch behind the water dispenser that could be bad,check both-mike
Nov 20, 2008 | Refrigerators
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSS25TGPWW / GSS25TGPCC Side by Side Refrigerator Logo
37 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
