Question about Fisher and Paykel Ovens
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
Fisher Paykel OD302 double wall oven. Removed the top cover to access components. Rear right corner there is an exhaust fan assembly (vent fan) with two lead wires: one red the other blue. The blue one came off. From what I can tell it connects to the distribution block located at the rear left. Lead can reach and easily plug onto either the 1st or 2nd connection section of the distribution block. I can't figure out which of the two terminals to reattach the blue wire to!
    Top Expert:
  • Fisher and P... Master
  • 50,583 Answers
Get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Posted on Dec 05, 2016
Upper oven takes forever to preheat
Deborah...all stoves have a row of fuses, usually under a strip cover. It sounds like one of the burner fuses have blown and needs replacing.If one is blown you would only have 110 volts on the element instead of 220 volts which would make the element only half as hot.
Dec 20, 2014 | Fisher and Paykel AeroTech Double OD302...
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
Error code f5, and inconsistent heating in top oven.
You need to replace the temperature sensor in the top oven cavity. I can't get you a part number or price because I can't find any service info without exact model number. Contact your local appliance parts store. It is easily replaceable with just a coupla' hand tools.
Dec 04, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Fischer paykel double drawer motor runs constantly and will start
Is it the actual oven fan located on the back wall of the cavity behind the fan shroud or is it the cooling fan which is at the top of the cavity and blows air across the top of the oven? The cooling fan can't actually be seen.
Aug 07, 2009 | Fisher and Paykel AeroTech Double - OD302M...
Fisher & Pak\ykel element connection
white or red are phase, black or blue neutral
Mar 25, 2017 | Fisher and Paykel AeroTech Double OD302...
Ovens Logo
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
