Question about HP 530 Notebook
I can not load the wireless network adapter drivers
The wireless can't connect to the internet even though it picks the signal from the server. the computer indicates that the wireless network adapter is not connected and thisis because windows can not load the wireless network adapter drivers.keep getting errorcode31
    Master:
    Sergeant:
  • 226 Answers
Try to uninstall the drivers for the network adapter and reinstall them
or
First lets confirm your issue. Right click on “Computer” or “My Computer” in XP. Select Manage and then on the right side select device manager. On the left if you see a yellow exclamation mark next to your drive and were getting any of the above error codes then we have a simple fix.
Go ahead and right click on the CD or DVD drive that has a yellow exclamation mark next to it and select delete or remove.
For Vista click the windows “start” button on the bottom left and in the search box type regedit . You will be asked to confirm your admin account. Just hit next or continue.
Now browse to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
It’s just like browsing through folders so don’t worry about it. if you get lost just start over. BE SURE you follow the path 100% There are many similar files and folders so double check they all match up.
Now that you are at the {4D36E965-E325-11CE-BFC1-08002BE10318} Folder on the right side you will see several entries. right Click and delete the Upperfilters and Lowerfilters. These will be remade once you reboot.
for XP follow the above but instead click the windows start button and then select run then type regedit .
Reboot your computer once you have removed the upper and lower fillters. When your computer boots back up it will see the drives as new devices. give it another 20-30 seconds to install the new device.
Posted on Jul 20, 2009
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
Using a Acer Aspire Revo. Running with linux Unbuntu 10.4lts. I have a BTHomeHub trying to connect my NWD-270N Wireless N-lite USB Adapter however it picked up the Hub and established a connection...
Select from the computers default internet networks, Recent computers are wireless enabled as the prefered networking. Attempting to introduce another network would share the connection capacity to any availabe signals. decide on the network type required. Pick wireless and disable the remaining networks to achieve an express signal reception and transmition.
Jan 29, 2011 | Zyxel NWD270N Wireless N USB Adapter...
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Internet connection/network adapter problem
If you are using the Windows own Wireless connection wizard (Wireless Zero Configuration service aka WZCSVC) this is designed to recheck every 20-30 mins for another connection this is your problem disable the service here download this tweak.
http://rapidshare.com/files/260751524/Disable.WZCSVC.reg
Then download and use the laptop NIC's own software to search for your Uni server and then connect using the WEP or PSK, this will solve your problem then create a profile in the NIC connection software and it will never forget.
LOL
Sep 27, 2009 | Acer Aspire 6930-6455 Notebook
Problems connecting, stuck on aquiring network/renewing IP addres
i want to down load the mother board drivers and utilities c.d,how will down load
Sep 01, 2009 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Laptop won't connect to new Belkin G Wireless Router
Just Install the hardware and insert the driver of the router...then follow the instruction...
May 10, 2009 | Belkin (F5D72304F5D7000) Router
Can't connect to internet
It sounds like the driver for the USB network device is not loaded correctly. So, you'll need to reinstall it from scratch. Unplug everything, install the software, then reattach the usb cable to the PC.
The other thing is, did you DISABLE the network adapter that was already in your PC when you added the USB network adapter? If not, you need to do that. If they are both active but only one is connected, the system could still be trying to use the other network adapter and tying up the resources in the process.
Jun 23, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Stupid router
SUE NETGEAR PURPOSE OF WIRELSS ADAPTER IS TO CONNECT WIRELESSLY, IDIOTS
May 26, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
HP 530 Notebook Logo
198 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
