Question about Goodman Heating & Cooling
I am replacing a Goodman Gas Valve and I need to know where to plug in the connectors.
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
What are the terminals marked on gas valve
Posted on Sep 20, 2017
I have a goodman gmp075-3 furnace, blower and igniter are working fine but not getting any gas to get furnace going
Check if 24 volts is being sent from the board to the gas valve, if not the board is nad and will need to be replaced, if there is 24 volts at the gas vlave terminals then the gas valve must be replaced.
Nov 08, 2012 | Goodman GMS90703BXA Heater
Very small amount of gas leaked from vent hole on gas valve for my Goodman 50,000 BTU furnace (LP gas) then stopped. What is the vent on the gas valve for?
Hello, peter, Maybe this will help you some.
Let me know, Mike
Sep 27, 2011 | Goodman GMS90703BXA Heater
I have a furnace goodman, the hsi glows then i hear a click ( there is 24 v in the gas valve after the click ) but the burners never ignate.
Hello, the first thing to check is if you are getting gas flow to the burners, if you are than the ignitor is bad and must be replaced. if you are not getting gas to the burners and are getting 24 volts to the gas valve then the gas valve is bad and must be replaced.
Feb 03, 2011 | Goodman Heating & Cooling
My goodman heater is a forced hot air gas heater and it will not fire up. the Glow plug lights up but I can not get a flame.
This sounds like the gas valve is either not opening, or you do not have gas at the unit. After the hot surface igniter glows, you should here another click a little bit afterwards. This click is the gas valve opening, then blows through the burners. Make sure there is gas to the unit first, and if so, the valve may need to be replaced. You could also have a problem with the control board or even the pressure switch sometimes. Hope this helps or at least points you in the right direction.
Nov 11, 2010 | Goodman GMS90703BXA Heater
Goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Jan 29, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman GMP075-3 ignition problem
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
32 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
