Question about Paslode Li-Ion Cordless Framing Nailer
My paslode Li-ion + Fuel framing nailer has delayed nail firing problems . I push in the safety, pull the trigger and then have to wait between 2-10 seconds before it fires
2 Suggested Answers
shane_tho79722
SOURCE: I have an angle Paslode finish nailer as soon as I installed the battery the fan starts running it will not stop until I remove the battery the gun has always been properly maintained it's been clean
Your Spark unit is faulty it will need replacing
Posted on Feb 09, 2016
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
Paslode 350 Framing nailer trigger does not fire.. Has worked until today, has the correct pressure, but the trigger feels dead.
make sure the safety is not bent what you can try and be careful is remove ALL nails and plug the tool into the air supply, find a small screwdriver and holding the nose up off work use the screwdriver to depress the trigger valve, if it works then you have a safety issue, if not then you have a trigger valve issue. Let me know if you need more help
Jan 18, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode f350s.just replaced all o rings,now when you pull the trigger air leaks out through the trigger,but only when depressed..will not fire nail.please help ..thanks bob
Simple. You have a leak you didn't have before. Either find it, or take it to someone who knows what they're doing. O-rings have a thickness, as well as a diameter. If you used generic rings, that's probably the problem. Use the repair kit by Paslode.
Paslode.com can tell you where your nearest dealer/repairer is.
HH
Dec 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Quit firing nails motor comes on but nothing happens when pulling trigger
I am assuming that you have changed the gas cylinder. Make sure you have the exact correct cylinder, because there are some that look like they fit, but don't quite seal. This unit requires battery charged for ignition and induction fan. And it requires fuel to drive the nail,.
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
My hitachi nr 90 gc nailer was always slow to fire a nail with about a second delay between pulling the trigger and firing the nail. now however the gun will only fire a nail once in about 20 attempts, and...
Trigger may be dirty, as an electrical switch the contacts can be intermittent. Also check to see if the safety plunger is set to correct depth and moving freely. Dirt can build up here......
Feb 14, 2010 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Gun does not fire every time
make sure the safety is being pushed in all the way
it will not fire unless the safety is fully engaged
Dec 12, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode Li-Ion Cordless Framing Nailer Logo
Top Paslode Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Paslode Electrical Supply Expert? Answer questions, earn points and help others
