What is the tonnage of a ruud UHQA 1010B air handler?
This unit is designed for 3.5 to 4 tons. The j14's are 1.5 to 2 tons. J17's are 2.5 to 3 tons. A j24 is 5 tons.
Hope this helps, It comes directly from my j21 factory manual on my air handler unit.
Posted on Jan 31, 2010
  • 614 Answers
1.5 to 2.0 tons
Posted on Jul 21, 2009
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
17AHJ11S13C01
need the model # for tonnage.
Jan 11, 2014 | Ruud Heating & Cooling
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Need a Coil for Air Handler
You can use any 2 ton coil that is setup for whatever refrigerant you are using in the condenser.... just match the tonnage, the refrigerant, and the size and you are good to go...
heatman101
Apr 22, 2010 | Ruud UAPA024 Air Conditioner
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Themostat problem no power
Your R terminal in your air-handler is the 24v power that goes to the tstat. Look at the air-handler and match the color wire. ALL tstats have a power wire going to them. If you aren't getting power, you probably have a break somewhere in the wiring close to the thermostat you are replacing.
Apr 07, 2009 | Ruud UBHC Air Conditioner
Need to find ac coils for RUUD ac in the Air Handler
follow the copper lines coming into the air handler.1 will be large and insulated and the other smaller and uninsulated.They attach to your evap coil.
Aug 18, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
1,753 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
