Question about Bunn Coffee Makers & Espresso Machines
My bunn comercial maker will not dispense water when the momentary switch / start switch is pressed. I replaced the switch and it still does not work
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Hot water dispenser does not dispense well
Most likely is the faucet/tap is broken inside and does not lift properly as the handle is raised. You can get a new tap which is easy to replace from your local Bunn distributor.
May 17, 2014 | Bunn DualĀ® (20900.0011)
I have a bunn CW series brewer. I filled the reserve with water and allowed to get hot. I then add additional water (1 glass pot) and it just starts to dispense without me hitting the "start" button. I...
Sounds like the switch is stuck in the operate position. Therefor once the machine hits temperature it just brews. Your local Bunn distributor should be able to recommend an engineer to replace the switch or supply the correct t,hope of switch if your confident enought Tom replace it yourself.
May 11, 2014 | Bunn CW 15-APS Coffee Maker
The brewer is on a gravity feed system, after the initial fill, whatever you put in is what comes out. as for the start button check the water connection on the back, there might be a problem with the solenoid.
Followed the directions to adjust the water level dispensed. While having the switch on the panel on "set" I clicked the start button to remove the required 2 sec intervals I needed then held...
While holding down the switch you will hear the solenoid start and stop 3 times. You should have to hold down the switch for about 10 seconds to get the program started. Make sure the white lever on the board is not on the L.
Sep 20, 2011 | Bunn CWTF15-TC
How do you clean the Bunn 10 cup classic comercial coffee maker it is a BX-B model?
To clean your brewer, with the machine still turned on, pour in 1 qt of white vinegar and let it sit in your brewer for 2 hours. At the end of 2 hours, you will flush it out with 8-10 decanters of water.
Dec 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Have a Bunn NHB. I cannot get more than 4 cups of
I work for BUNN. Has your issue been resolved? The rocker arm is inside the pour in bowl (where you pour in the water for brewing). To get to it you have to take off the entire top lid (not just the spin lid above the pouring area). That can be removed by lifting it up and then you simply snap it back on when you are finished. Hope this helps.
Jan 03, 2010 | Bunn NHB Coffee Maker
Does not heat water or dispense water and warmer light does not turn on i have tried multiple times to fill the resivor but still nothing. i have followed the instructions to the letter and to no avail i...
There may be a thermal cut-off switch inside that has failed. I've by-passed the switch myself, but don't recommend it. Another option is to replace the cut-off switch.
Sep 19, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
