Question about Crafts & Hobbies
I have a new 104 MTH Long Island engine and tender and I cannot get it to run.
I have a Lionel transformer... cleaned the tracks... the transformer has power...
    Top Expert:
  • 44,073 Answers
The locomotive may be defective as received. Try applying power directly to it to confirm.
Posted on Dec 05, 2016
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Feb 07, 2015 | Crafts & Hobbies
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
How often should tracks be cleaned. Engine slows down after running for a while
It depends upon how much you run your trains. Run your finger or clean cloth on the rail. If you see a dark mark your tracks need cleaning. You can also run another set of wires from the transformer to the spot on the track furthest from the transformer. You can even run a third or fourth equally spaced apart if you have large loops and long and heavy trains.
Dec 04, 2011 | Lionel 40 Watt Transformer Train Set Track...
My cw-80 Lionel transformer has button issues when operating both traditional and tmcc loco. the horn and bell sounds are goofy. and on some of my traditionaltenders the sounds are still on when the...
The CW-80 is not suited for electronic sound systems. The output is non-sinusoidal. When electronic sounds are generated for some locos, the sound will be garbled. Use another power source. The Z1000 MTH power source or similar is recommended as are many other older Lionel standard power xfmrs. For the sound stay on problem with switch off, try putting a fixed load on the tracks ie: An accessory of some kind (lights etc). Usually a fixed electrical load will fix this problem. Overall, I would recommend changing out the power source and save yourself a lot of headache..
May 14, 2011 | Lionel Cw 80 Transformer
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Crafts & Hobbies Logo
383 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
