Question about Stihl Garden
My Stihl Ts800 idles rough and when you squeeze the trigger it revs high and then low.When it left to idle it just cuts out.
    Top Expert:
  • Stihl Master
  • 77,947 Answers
You need to clean the carburetor jets you have dirt in them most likely.
Posted on Dec 06, 2016
I have a Stihl MS 181C. It starts, no problem, but the chain runs on tickover and when I squeeze the throttle it cuts out. Can you please advise.
fuel filter --air filter --bad fuel--carb /cleaning /rebuild /replace-fuel line - binding clutch--tension to tight on chain
Aug 14, 2017 | Stihl Garden
Saw wont rev up or idle
First thing, try new gas.
If that doesn't do it, you need to adjust the low and high speed circuits on the carb. A good starting point is 1.5 turns out from fully seated. On that saw I'm not positive if you will have access to the adjustment screws unless you pull off the plastic caps that may be covering them.
Feb 01, 2014 | Stihl Garden
Stihl carb diagram
Here is the two types of carb fitted to the TS700/TS800
May 17, 2013 | Stihl 43991 - TS700 & TS800 Cut-off saw...
Car engine idles really high then really low, why?
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
Bad miss at idle?
Stumbling and stalling at idle after engine rebuild?
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
Engine stumbles coming off idle when warm?
Erratic idle on car?
Cold start problem and vehicle shudder around 2500 to 3500 rpms
Low idle when cold out side?
GMC Sonoma Stalls and idles low
GMC Idle Air Control (IAC) Valve Replacing?
1996 Camry intermittent engine failure while idle?
Engine quits at idle?
Car overheats and Air blows hot at idle?
High Idle Problem
While stop engine idles like cylinder missing?
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
High rpm in neutral? Inconsistant high RPM in neutral?
Vehicle stumbling at idle and shows code 54?
Rough idle, staling and Erratic shifting?
These details will help.
Feb 15, 2013 | 2003 Pontiac Grand Am
2000 yamaha r1 revs high at normal driving speeds at normal operating temps
you must adjust the idling level..theres a screw way above the shifter (somewhere there) connected to the end of metal plate, turn to the right and idling level is high like yours, turn to the left and idling level is figure where it'll sit right
Sep 26, 2012 | 2000 Yamaha YZF-R1
Hello, i have a stihl ts400 and i just rebuilt the topend(crank,piston,cyl,all bearings and seals.Fires up easy, idles fine,revs fine, but when you hold the throttle down it doesent want to hit rev limiter...
There is not an actual rev limiter. The top end is controlled by the carb. You actually want it to sound a bit rich at full throttle so that it has enough fuel when cutting under a load. What causes me some alarm is the revving up part. If it revs too fast that is a lean condition and can quickly ruin the piston and cylinder much like running straight gas. A torn intake boot can cause this. The high speed spec for the TS400 is 9,600 rpm + OR - 500 RPM. Your saw may not have a needle to adjust the high side as some have only the low speed adjuster. Also when you disassemble and clean the carb always use a new kit with the gaskets and diaphragm. Any Stihl dealer can furnish the kits and they aren't terribly expensive. Often between $10-20.
Jun 26, 2012 | Saws
First my Stihl Quikcut was getting too much gas now after rebuilding the carb it's not getting enough
Not sure who told you about the compression but that is not true, are you sure the throttle rod is actually pushing the throttle shaft open?
Mar 17, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
How do i set up the carburetor on a sthil ts400
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
Feb 24, 2011 | Stihl Ts400 Cut Off Saw Carb Carburetor...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
114 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
