Yamaha g3 sun classic golf cart gas peddle goes to floor does not spring back
SOURCE: Removing Yamaha rear tire (1100 Classic)
do you mean remove the wheel? tires are best left to a shop to do as they have the machine. drive shaft yes? undo all bolts thru frame to final drive casing. slacken wheel nut but do not remove spindle, pull wheel back and out of the frame the drive shaft comes with it, tace out spindle and now lift final drive from wheel, there may be a spacer which might fall out. done deal..
SOURCE: how to lower the idle on a 2002 yamaha 650 v-star classic?
under the left side of the gas tank you will see i black knob/screw at the end of what looks like a hose. the knob faces the rear of bike. that adjusts the idle. its real easy to find and the only adjustment you can make to the carbs.
SOURCE: Sun Mountain Speed Cart V1 users guide
I am trying to replace the lower bag holder with the new non bungie type. They didn't send instructions. Do I have to drill new holes in the frame to make this assembly work? The top one was a straight replacement.
