Question about NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter
I have tryed different universal ac adapter to get power with card. Did not work. What name brand should I try.
    Master:
    Sergeant:
  • 226 Answers
Power should run thru the laptop to the card if not i would try the company that made it website they should have replacement power cables
Posted on Jul 20, 2009
There seems to be no power to our shredder.
Beverly, the power supply for shredder is probably bad. If it has a external power supply, take old power supply with you to a electronics shop and have them match it up for you, with a universal power supply.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
universal power supply Google Search
http://www.walmart.com/c/kp/universal-ac-dc-adapters
Results for Universal AC Power Adapter
SS103 Universal Power AC DC Adapter 500mA
Mar 11, 2016 | Office Equipment & Supplies
No power no power light. Its as if there is no power. Ive checked cord and there is power to it
Try using that ac adapter on a different computer if possible to check if it charges. Or try using a different ac adapter. If your laptop works using a different ac adapter, your ac adapter is busted. If it does the same thing using a different ac adapter it is a problem with your laptop and needs a repair.
Apr 22, 2011 | Acer Computers & Internet
My Toshiba AC/DC Adapter model number ADP-75SB AB for my satellite computer is not working anymore. I have tried different troubleshooting efforts but all have been unsuccessful in getting my computer to...
Is the ac adapter detected?
If YES, and it doesn't charge the battery, but it turns ON the laptop it means that the battery is the one not holding a charge.
If NO. Try to change the power cord that goes to the wall (that part is detachable) with good known power cord. If it does the same then definitely there's a problem with the ac adapter. You can contact the Toshiba sales department (1-800-8674422) or toshiba direct (1-800-3160920).
If the computer powers ON, both ac adapter and battery are detected but no display, then the problem is the system board.
Mar 15, 2011 | Toshiba Computers & Internet
Power will not turn on
Power drain pc first. Remove battery and unplug Ac adapter. Then press and hold power button for 15-20 sec. Then put back in battery and ac adapter. Try if it will turn on. If not, try one at a time, battery and ac adapter to turn pc on. If it turns on with battery only, possible ac adapter issue. Try a different outlet to plug it in. If still no go, try a different ac adapter. If it doesnt work still, possibly it is a motherboard issue.
May 25, 2010 | Acer TravelMate 2480-2968 Notebook
Looking for the ac adapter for Acer Aspire 4315
if your looking for Charger then thre is Universal adepter wich work with all leptops try then brand name is Tragus product
Apr 19, 2010 | Acer Aspire 4315-2963 Notebook
I have a dell Insiron 1526. we thought it was the power port and changed it. they charger shows a green light when plugged in and when you add the computer it starts blinking but the computer will not turn...
try to use a different power adapter or try your ac on a different system so you can determine if the issue is with the ac adapter or on the system. if the power adapter works on a different system, try to remove any external device as well as the ac adapter and the battery. while the ac adapter and battery is out, press and hold the power button for about 15seconds. then reconnect any power source and turn on the system. if it still doesnt turn on, remove memory, expansion cards, hard drive and optical drive then turn on the system. if it's still not turning on, the motherboard is faulty. but if it do turned on, reconnect the removed components one by one so you will determine which component is causing the issue. hope it'll help. good day. =)
Dec 22, 2009 | Dell Inspiron 6400 Notebook
I've had my Gateway M-6843 Notebook for about 18 months. Since the day I bought it from Best Buy, the AC adapter port has been finicky. I'll be using the laptop with the adapter plugged in and the...
This problem can be caused by mainly two different things. It is either the AC Adapter itself and has a short in it, or sometimes it is caused by the Power Jack inside the laptop. Are you familiar with how to read a voltmeter? I can walk you through testing your adapter. If it is either issue, I would recommend trying to fix through warranty if possible, because the power jack repair can be expensive. If you need to replace the AC adapter, I recommend a genuine adapter, as universal adapters and cheap knockoff brands will cause issues with your laptop and usually not last very long.
Dec 11, 2009 | Gateway M-6843 Notebook
Error E11 with DC4800 camera
This error "may" be associated with a battery problem. Is it possible that the battery is not charging properly.
Other things to try are as follows
1. Connect the camera to the AC adapter or insert onto the Camera Dock and press the Power button on the camera
2.
  • Remove all sources of power (batteries and AC Adapter) from the camera.
  • Remove the Kodak Picture Card or Compactflash Card.
  • Wait a few seconds.
  • Press the Power button twice.
  • Connect the appropriate Kodak AC Adapter to the camera.
NOTE: If you don't have the correct AC adapter, insert a set of fresh or fully charged batteries, according to the User's Guide.
3. The COMPACTFLASH Card could be corrupt. Reformat the card using a card reader or a PCMCIA card adapter in a notebook computer. ***Remember, reformatting erases all information from the card***
4. Try a different CF card as I have seen them fail causling errors.
Jul 01, 2008 | Kodak Cameras
ACER ASPIRE 3002WLCI
Probably a voltage regulator, they are usually available on ebay, but I suggest having it done at a repair centre.
Jan 28, 2008 | Acer Aspire 3000 Notebook
NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC Card Adapter (USBP2D20) Serial Adapter Logo
173 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
