Question about Cell Phones
Directions for charging my new cell phone - Cell Phones
  • Cell Phones Master
  • 17,452 Answers
Connect the lead, plug it into the wall. Leave 7 to 8 hours.
Posted on Dec 05, 2016
How do i charge my tom tom
How do I charge my device? - TomTom
us.support.tomtom.com/.../how-do-i-charge-my-device%3F
TomTomApr 15, 2013 - If you only charge your TomTom while it is in use, it may not charge to capacity. To fully charge your TomTom, it is best to charge the device indoors. Most newer TomTom products can be charged directly through USB, simply by connecting the USB cable or dock to your computer.
Dec 18, 2015 | Cell Phones
How do I activate my phone with new sin card
The new sim should have come with instructions. You can do it online. Make sure your phone is charged. Insert your new sim and than go to the website and click "Activate / Reactivate" phone. Than follow the directions.
Nov 12, 2014 | Tracfone Wireless LG 440G
My phone won't charge and I know for factor it the part that you plug the charger up too
If it's a problem with the SOCKET(Not "part you plug the charger up") then you can either charge the battery directly or get a new phone
Aug 25, 2013 | ZTE At&t Avail Z990 Touchscreen Android...
PHONE DOES NOT HOLD A CHARGE, HAVE TO CHARGE EVERYDAY
If your phone is not holding a charge unfortunately you will need to get a battery replacement for it. If the phone is still under warranty you can contact Samsung directly for a replacement free of charge. If not, you may look for a new battery on sites such as Ebay or Newegg.com
Click here for samsung support
Regards,
G33k
May 12, 2011 | Samsung M320 Cell Phone
While on charger, the charge indicator LED is flashing instead of being lit continually. Battery doesn't seem to be charging properly. I've tried both the Charging cradle and direct connect. Same results....
Try a few things:
- If both of the above charging situations plug into a computer or car, try plugging into the wall. The amount of power drawn from other sources is lower than from a standard outlet, and if the phone is very low, this can be an issue.
- If both of the above charging solutions use one cable, try another cable. This will help you identify if the issue is with the cable or the phone.
- If different cables/power sources produce the same result, the problem is definitely with your phone. I would suspect a problem with the charging port, but it is also possible that the battery has failed. Try swapping a new battery (they should be available cheaply online if you don't know someone else with the same model phone), as well as cleaning your charging port with some canned air, and possibly a toothpick (be very gentle!) if you can see some debris.
Generally, charging ports are directly attached to the motherboard, making replacing just the port difficult and not cost effective. If the port is kaput, you may need another phone.
Mar 05, 2011 | Casio G'zOne Rock Cell Phone
My phone is not turning on
have you checked your battery? try to use anew one, some problem with this model is the battery charging IC, sometimes it went into abnormal state, even though you just charge it and thingking that it was fully charged, well the power does not goes directly to the battery, so try to use a new battery
Nov 15, 2009 | Sony Ericsson W910i Cellular Phone
I got Nokia N99i chinese version cellular phone with 2 batteries, one battery worked for 3 months & now charging isn't holding & other battery can't charge since bought. How can i buy a new battery...
Men you really got a problem!
ok Try Ebay, if not www.alibaba.com sure you can find the batery there.
Other ways:
the batery its not charging at all?
you can buy a Universal Batery Cell phone carger, these ones got the ability of charge some times baterys whit thiis kind of problem.
Make an adaptation from other batery (just look details as Voltage, amps) sometimes its require soldering directly to your phone :S (pretty extreme)
Oct 17, 2009 | Cell Phones
I have Nokia E65.Whenever I set it on charging it does not charge, rather the movement of charging cell continuosly shown.But after a lot of time the result is not-chartged even by a single cell.What is...
two problems can be there
  1. U r battery is faulty.. it needs to be replaced.. to check tht put it in sum other phone and charge it or chare it using battery charger in whch battery is directly fitted on the charger..
  2. other problem could be with the charging circuitry of the phone.If ur battery charges from other sources like mentioned above thn ur phones circuitry is damaged
  3. also there is a possibility of faultycharger.. so try charging with sm other charger
Sep 06, 2009 | Nokia e65 Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
