Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
Fisher Paykel OD302 double wall oven. Exhaust fan assy (vent fan) wiring question related to distribution block.
Fisher Paykel OD302 double wall oven. Removed the top cover to access components. Rear right corner there is an exhaust fan assembly (vent fan) with two lead wires: one red the other blue. The blue one came off. From what I can tell it connects to the distribution block located at the rear left. Lead can reach and easily plug onto either the 1st or 2nd connection section of the distribution block. I can't figure out which of the two terminals to reattach the blue wire to!
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: I'm changing the broil element
Hi
Please check this video if you want to replace broil element yourself:
Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 14, 2011
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
After using self cleaning oven temp will not rise above 80?
call your local repairman something melted from the excessive heat of self cleaning
Mar 12, 2016 | Fisher and Paykel AeroTech Double OD302...
Cannot unlock the oven...
Can you get,on-line,an exploded view of your unit? then you'd be able to see what may be hanging up preventing unlocking.
Mar 30, 2014 | Fisher and Paykel AeroTech Double OD302...
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Our Fisher Paykel OS302 completly overheated during its cleaning cycle. Oven door is locked, nothing comes on and Fisher Paykel will not help, it is only 4 years old, we have made many calls, and certified...
The thermostats have probably blown. There is a rebuild kit for this problem, it is not cheap nor is the labor to do it. Try shutting off the breaker for a few minutes... sometimes it will reset, but not heat. In any event you should have the new thermostat kit installed. F/P should at least be able to give you the tele. of a Tech., keep in mind that depending on where you live there are very few technicians that are certified to fix these.
Jul 08, 2009 | Fisher and Paykel AeroTech Double OD302...
How to turn oven on kelvinator wall
Is there a hand diagram labelling one of the button. Auto/Manual switch?.
Apr 11, 2009 | Fisher and Paykel AeroTech Double OD302...
Open Questions:
See all Fisher and Paykel AeroTech Double OD302 Electric Questions
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Flipper
Level 1 Expert
 Fix Your Board
Fix Your Board
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
