Question about Dyson V8 Absolute Bagless Cordless Stick Vacuum
V8absolute stick. How do I open the canister to let the dirt out
Dirt devil turbo clean sd40060 Cyclonic vacuum. Was given it as a present. Floor tool won't spin. Checked everything! Belt, for hair through out. All ok. Why isn't it working?
You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Aug 08, 2015 | Dirt Devil Vacuums
Where can I get a Manual for a RediVac canister vacuum?
Hello, Sears sells this model you can call sears parts and give them model number and they can help you.
Jun 01, 2014 | Readivac 36721 Canister Vacuum
Latch on my dirt devil total pet canister to empty is stuck. how do I make it open
I bet I have the same problem as you. My vacuums canister was put back together backwards and now will not move far enough to click unlocked. I am not sure how to fix this and I cant find anyone on any forums who do :( If you figure it out post it! So far ime just trying to muscle it open.
Mar 26, 2012 | Dirt Devil Breeze Bagless VacuumVacuum
Ho wdo I change the filter on the Eureka optima.. HELP!!! thank U !
open the canister like you are going to empty out the dirt canister. there will be a tab to push in near the back side of the machine on the lid of the dirt canister. It has a push tab at the back and a stationary tab that locks in at the front.
If you do not have a new filter handy, you can brush out as much dirt as you can with say an old tooth brush or paint brush. you will want to replace the filter on this unit at least once a year.
good luck.
Nov 19, 2010 | Eureka 431A Optima Bagless Upright Vacuum
I have a Dirt Devil M130000 I Dual, which just shut off.
yOU MIGHT TRY LOOKING DEEP INTO THE DEVIL PAST THE CANISTER INTAKE AS THIS IS WHERE THEY CAN GET A HUGE CLOG THAT YOU CAN'T SE UNLESS YOU STICK YOUR HAND WAY IN THE UBE. DO THID WITH THE DEVIL TURNED OFF. CHECK FOR A SHORT IN THE CORD AS WELL BE SAFE FIRST.
Jul 23, 2010 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
HOW DO I EMPY
Remove the canister/dirt bin by pressing the button above the handle where it says Dyson. Next push the red or gray (depends on your model) trigger down whilst holding the canister over a trashcan. The bin door will open and release the dirt.
Jul 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I am unable to open the canister to remove the old bag, unclipping the 2 clips on the side does not release the canister. What am I doing wrong?
Overtime the dirt canister can get somewhat stuck. Once you unclip it, you will need to apply some force and pull down. The dirt canister should release.
Apr 18, 2009 | Broan-NuTone CV350 Central Vacuum
Dirt canister lid is stuck on
push it back in till you hear it click.pres the button and hold and pull the dirt cup at the same time.please leave feedback
Oct 07, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Dyson dc07
might be clogged with dirt, take the canister to the trash bin, pull the trigger and try pulling it open from the bottom at the same time, there is also a way to remove the top of the canister where the handle is from the bottom clear canister part by the back side, there is a little lever.
Mar 23, 2008 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Dyson V8 Absolute Bagless Cordless Stick Vacuum Logo
29 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
