Question about Boss Car Audio & Video
Just installed boss 648UA and when i put a CD in it doesn't play. It just says read CD then goes back to radio
petraman7
  • 1175 Answers
SOURCE: after putting a cd in,
Hi...
Find someone whos not afraid of technical stuff to clean the laser lens and rails that the laser pick-up runs on.
Also get the drawer belt checked for loosey-goosey
Posted on Mar 25, 2009
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
  • 447 Answers
SOURCE: My radio wont play Cd's. Everytime I put in a cd,
laser eye is bad, sounds likeit needs new pick up
Posted on Feb 09, 2010
DJAJ-NE
  • 54 Answers
SOURCE: doesn t reading the cd
hey,
also mention how old are ur CDJ and does it play original cds. Did you get any error code.
thx
djajay
Posted on Aug 04, 2010
lokipoki
  • 8 Answers
SOURCE: radio does not play cd
This is yet another problem that can be traced back to faulty PCM in equinox.
I have same issue. I stopped using it and just use MP3 or satellite radio.
Posted on Sep 25, 2010
Why do I have to push the reset button before operating for the first time on Boss Audio 648UA
Because when the unit was built, where ever that might be in the world the clock an other systems were set for their area. A disk was run through telling the processor certain things to do an a technician adjusted what ever needed correcting. So a reset of the timing an processing chips are needed.
Jan 28, 2015 | Boss Car Audio & Video
Boss bv9354 spitting out cds and dvds and not playing them
Take it back and get your money.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 22, 2012 | Boss Car Audio & Video
How to install Boss audio systems AVA 1210
I tried to install my boss Ava 1210-7 equalizer but I have a 2din001 radio i have a rca jack plug at the back of the radio say AV in its 3 jacks red,white and yellow. I only connect a rca jack to the red and white and leave out the yellow one when I put that to my EQ CD rca section it doesn't work I don't know what to do next! Can someone help Out?
The picture is the rca jack section from the back of my radio
Mar 05, 2012 | Boss Car Audio & Video
How install?
. I have a Boss 612UA. When I plug it in it gets very hot in the back of the unit near the plug. I checked the wiring and it is correct.
Nov 13, 2011 | Boss Multimedia Player 612 UA
First@gmail.com, 2006 malibu cd player keeps the cd, doesn't eject or take the cd, but plays fine. Is there a part I can replace myself?
Is it a burned CD-R? I know (this is probably the same on a 2006) that on my 2005 if you put one in, it will play fine then lock the disc in. There is a fuse pannel on the passenger side on the center of the console towards the front of the car. Just pull the plastic cover off. Find the 10A fuse by the little grey box, and a blue and white circle. (or just look for the fuse labled "RADIO" on the map inside the plastic cover and then locate it in the fuse box). Turn the key off, pull the fuse, turn the key back on for a sec and the radio will not come on. turn the key off, put the fuse back in and turn the key on. the disc should either come out or you will have to push eject. This may or may not work, some people say it doesn't work for them. (this may reset the radio number buttons memory). Hope this helps!
Aug 21, 2011 | 2005 Chevrolet Malibu
Your CD player's lens is not working, meaning either if you can open it and change the lens or install a new stereo, see which solution is cheaper.( you can find stereos for around $35) . Good Luck
Feb 09, 2010 | 2001 Pontiac Grand Prix
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
My BOSS 380DVD will not load DVD's, it will play CD and the radio, but the DVD player stopped
This is normally caused by a dirty lens. It will play cds because they are easier to read, but dvds use the whole lens to play. You need to run a lens cleaner in your system and it will work like it should.
Oct 27, 2009 | Bose 3·2·1 II System
Car cd changer not working!
try pulling the fuse and resetting it, make shure its the +12v cont wire
Don
Dec 29, 2007 | JVC KD-S680 CD Player
Car Audio & Video Logo
51 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
