Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
Fisher Paykel OD302 double wall oven. Question regarding the top mounted exhaust fan assembly and the electrical distribution block.
Fisher Paykel OD302 double wall oven. Removed the top cover to access components. Rear right corner there is an exhaust fan assembly (vent fan) with two lead wires: one red the other blue. The blue one came off. From what I can tell it connects to the distribution block located at the rear left. Lead can reach and easily plug onto either the 1st or 2nd connection section of the distribution block. I can't figure out which of the two terminals to reattach the blue wire to!
    Sergeant:
  • Fisher and P... Expert
  • 467 Answers
Blue is normally your neutral wire and not live
Posted on Feb 10, 2018
  • 4090 Answers
SOURCE: I have a F & P wall double oven model OD302,
The name F&P says it all! If there was any brand that gave the most problems, in products then F&P is the first on the list. With LG as the second
You say this is possibly a new installation of only 2 weeks. Don't dither around seeing if its a simple fix, get the installers/sellers back to fix it . It will probably need replacing as the control is faulty.
Thanks for using FIXYA
Posted on Dec 03, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
KevinWhite
  • 1902 Answers
SOURCE: Fisher & Paykel double wall
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 03, 2011
SOURCE: My Fisher Paykel AeroTek OD302 double oven has
Ovens Fisher&Paykel takes a long time to warm up.
What could the problem
Posted on Feb 16, 2011
Daniel S
  • 4323 Answers
SOURCE: I'm changing the broil element
Hi
Please check this video if you want to replace broil element yourself:
Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 14, 2011
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
Sets the Clock of the oven
why bother the main oven switch should be off every night anyway which turns the clock
Jun 18, 2014 | Fisher and Paykel AeroTech Double OD302...
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
Error code f5, and inconsistent heating in top oven.
You need to replace the temperature sensor in the top oven cavity. I can't get you a part number or price because I can't find any service info without exact model number. Contact your local appliance parts store. It is easily replaceable with just a coupla' hand tools.
Dec 04, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Fischer paykel double drawer motor runs constantly and will start
Is it the actual oven fan located on the back wall of the cavity behind the fan shroud or is it the cooling fan which is at the top of the cavity and blows air across the top of the oven? The cooling fan can't actually be seen.
Aug 07, 2009 | Fisher and Paykel AeroTech Double - OD302M...
Fisher & Pak\ykel element connection
white or red are phase, black or blue neutral
Mar 25, 2017 | Fisher and Paykel AeroTech Double OD302...
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
53 people viewed this question
Top Fisher and Paykel Ovens Experts
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
