Question about HP Office Equipment & Supplies
I don't have word. I have a Mac and an Hp printer. I can print the address on paper but can't figure out how to get it on an envelope.
    Top Expert:
  • HP Master
  • 8,204 Answers
Verify printing options..try this.
  1. On the Mailings tab, in the Create group, click Envelopes.
  2. Click Options, and then click the Envelope Options tab.
  3. In the Envelope size box, click the choice that matches the size of your envelope. ...
  4. Click the Printing Options tab. ...
  5. Load the envelope as indicated in the dialog box.
  6. Click OK.
More items...
Create and print a single envelope - Word - Office Support
Posted on Dec 05, 2016
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
Printing large (6.1 X 8.13) Costco Envelopes Mac OS 10.6, Word
Yep, I reckon you will be addressing them by hand.
HP specifications are:
Basis weight < 90 gsm
Max 5.5 mil single layer thickness
< 5mm curl
< 6% moisture
Max size = B5
Corners need to be well folded, with no more than 2 thicknesses of paper
Envelopes must lay flat
Paper grain should be diagonal to the direction of feed
No clasps, snaps, ties, strings or windows.
Do not use envelopes made of synthetic materials
Use the manual feed tray
Use the face up output bin
Do not use envelopes having an open flap with adhesive exposed, have very smooth, shiny, rough, textured or deeply embossed surfaces, or irregular shape.
As you can see, there are plenty of do's and don'ts. Envelope feeding is always tricky, especially if the envelopes are not specifically designed and made for Laser printers,
Dec 08, 2009 | HP LaserJet 4050n Printer
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Envelopes won't print
where do i insert envelope to print address?
Apr 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer not printing address on envelope
In Print Options, go to Preferences- - - - ->Paper Type- - - - ->Select the size of your Envelop- - - -Apply.
You will be able to print on Envelop after this.
Apr 15, 2009 | HP Deskjet 6940 InkJet Printer
Print Envelopes on HP Photosmart 7280
This is a paper size problem with the software, go to page setup and under "Paper Size" choose "User Defined" or "Custom" and fill in all of the dimensional information about the envelope and save with a name you will recognize. Now, when you print make sure you have selected the envelope from the paper list and you should be good to go. If you need further assistance, click "Ask Me" and I will answer your request as soon as I can.
Oct 07, 2008 | HP Photosmart C7280 Printer
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
hi friend here is link for your 24 hour online technisoin is tehre here is lin for it u can chat with him he will guide u what do technision
Apr 13, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP 712C Printer won't print envelopes
hi dear
Choose envelopes that are close to 20-lb paper in weight and thickness. Also, make sure that the adhesive on the envelope is capable of withstanding the heat that the fuser puts out to keep the printing on the page. If you don’t, the envelopes will come out of the printer already sealed. If envelopes are coming out of the printer wrinkled, they may be too stiff for the paper path. Open the rear of the printer and let them exit at that location instead.
Mar 19, 2008 | HP DeskJet 712c InkJet Printer
35 people viewed this question
Ben Johnson
