Question about Health & Beauty
How to open grip part of Brookstone #235333 massager
I've removed the screws securing the head, as well as the upper-neck "hidden" screws. How do I get the handle to separate? It has a rubber grip, with no apparent fasteners. I'm guessing that I have to slit the grip all of the way down, but that sounds irreversible. FWIW, I'm trying to repair a broken power cord where it enters the bottom of the unit's handle.
alicantecoli
  • 22246 Answers
SOURCE: How to repair Suzuki Forenza interior driver's door handle?
you answered your own question,ease the door panel with two screwdrivers ,one either side of the plastic clip and watch for the mastic
Posted on Jan 23, 2009
SOURCE: Opening the case to repair broken power connector
FIRST FAIR WARNING: This take apart is best left to the repair tech's at an authorized repair facility. There are 6 snaps, two on the top, two on the bottom and one on eash side. I used a thin blunt tip letter opener and started at the top. This didn't leave any marks on the case that would tip off the repair tech's that you goobered it up inside which you will do if you proceed! Release the two at the top first, then the two on the bottom. Now release the one on the side where the power button is located. Open the case on the power button side only about 1/4 inch and slide the bottom off the top being careful not to separate the power cord and headphone connector plugs from the board that they a fastened to inside the case. SECOND FAIR WARNING: It is very easy to pull the connector plugs from the board and this will really convince the repair tech's that you ruined your $350 GPS. Good luck and don't say I didn't warn you!!!!!!
Posted on Feb 16, 2009
SOURCE: Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Posted on May 25, 2009
SOURCE: Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Posted on Aug 12, 2009
SOURCE: How can I disassemble a Radial I-pod docking
hiya, i just had the same problem, where as my ipod dock connector didnt work, so i took it to the shop where i bought it and they said it wasnt repairable,, not taking this as an answer i went over to a mates house who is a lecky and asked him to repair it,,, we then come onto the snag of not being able to open it to get to the fault to solve this we got a bit mad at it and accidently dropped it on the floor :P where the 2 mesh panels came off showing over 20 new screws yes i said 20!!!! all that was holding the mesh was a lot!!!!! of glue..... after we took the many screws out we found out the reason why the shop said it wasnt repairable.... the manufacturer has put loads and loads of glue on everything stopping anyone from removing any of the connectors... we spent a good hour trying to remove the silly amount of glue but to no avail...
So if i was you i would bin it and get a new one...
Posted on Aug 24, 2009
Can the batteries be replaced on the Brookstone theraSpa massager
I can solder the proper chemistry batteries together and replace any pack they have in there....but I can't figure out how to get in. No screws visible anywhere.
Nov 12, 2014 | Brookstone Theraspa Turbo Massager
Tip
Battery replacement in Xantrex XPower Powerpack 600 > 600 watts 12 VDC >...
Battery replacement will require opening the case of the Powerpack 600. The four rubber feet must be removed first (Phillips head #2 screwdriver). Next the two orange handle halves come off starting on the radio side. The screw heads may be either 9/32" or 1/4" heads depending on age of your Powerpack 600. Use either a 9/32" or 1/4" nutdriver to remove the screws. The orange handle halves swing open like a clamshell at the carrying handle and lift off. The orange handle half on the flashlight side has two hidden latches in the handle area that must be released with a flat head screwdriver first before that half can be fully removed. Now that the orange handles are out of the way, slip off the bumpy rubber handgrip from the gray handle. On the radio side of the gray plastic case are 9 Phillips head #2 screws that are in recessed holes to remove. Once those screws are removed, the gray plastic case seperates in half and you can unplug the two pin connector going to the radio and set the radio half aside. You are now inside the Powerpack 600 and can replace the battery if needed.<br><br>Replacement 12 volt, 28ah battery numbers:<br>Sealake # FM12280<br>Zipp Battery # 12V-28AH-T3<br>CSB # GP12260<br>Powersonic PDC-12260<br>Tempest # TD28-12<br>Panasonic LC-C1228PG<br>Universal Power Group # UB12260<br>BB Battery # BP28-12
on Sep 01, 2013 | Xantrex XPower Powerpack 600 > 600 Watts...
Tip
How to massage the neck during a neck pain
Neck pain can be caused by injury, stress or by other health problems, including some that could have serious consequences.
One of the most common causes of neck pain, and sometimes headaches, is poor posture.
Your neck contains bones, joints, tendons, ligaments, muscles and nerves, any of which can hurt. Neck pain also may come from regions near your neck, such as your head and shoulders.
Giving Neck Massage
1. Place yourself at your partners head, while they are lying on their back. Oil the front of the body, starting with hands on their upper chest, then move down over the breastbone and back up the sides of the body to the starting position. Place hands on the upper chest, fingers pointing toward each other and press down, gliding the hands out toward the top of the arm.
2. Cradle the head in one hand and turn it slightly toward the right. With the other hand, glide firmly out from the center of the chest to the top of the arm, back along the top of the shoulder, and up the back of the neck to the base of the skull.
3. Make small circles along the back of the neck to release tension, then continue down the side of the neck to the chest. Stroke firmly down the side of the neck and out along the top of the shoulder, stretching the neck muscles.
4. Turn the head back to the center with both hands supporting the head under the neck, and pull gently to stretch out the neck muscles.
5. Turn the head to the opposite side and repeat the sequence for the other shoulder. Return the head to the center and pull gently. Make small, circular movements up the back of the neck to the skull and then stroke up the back of the head and off.
Heat can help relax sore muscles, but it sometimes aggravates inflammation, so use it with caution. Apply heat or ice for 15 to 20 minutes, with a 40-minute rest between applications.
For pain that doesn't get better, your doctor may recommend:
Physical therapy. Heat, ice or similar treatments combined with an appropriate stretching and muscle strengthening program may enhance the structures that support your cervical spine. Such treatments are often all you need for neck pain.
Pain medications. Your doctor may prescribe stronger pain medicine than what you can get over-the-counter. Opioid analgesics are sometimes used briefly to treat acute neck pain. Muscle relaxants also may be prescribed.
Also see your doctor if the following signs and symptoms occur together with neck pain:
Severe pain from an injury. After head or neck trauma, such as whiplash or a blow to your head, see your doctor immediately. Severe pain over a bone might indicate a fracture or an injury to a ligament.
Shooting pain. Pain radiating to your shoulder, through your shoulder blades or down your arm, or numbness or tingling in your fingers, may indicate nerve irritation. Neck pain from nerve irritation can last from three to six months or longer. Because serious problems may occur after continued nerve irritation, see your doctor.
Loss of strength. Weakness in an arm or a leg, walking with a stiff leg, or shuffling your feet indicates the need for immediate evaluation.
on Jul 08, 2010 | Luggage & Travel
How do i replace grips on 2009 electra glide ultra classic
For twist grip equipped motorcycles to remove the throttle or right side grip remove the upper and lower switch housing screws, loosen the upper screw securing the handlebar clamp to the master cylinder housing. Remove the lower clamp screw with flat washer, separate the upper and lower switch housings and remove the throttle grip from the end of the handlebar. (To remove the throttle grip, a slight tug may be necessary to release index pins in grip from receptacle in seal cap of twist
grip sensor.)
With throttle cables, to remove the throttle or right side grip slide the rubber boot off of each cable adjuster, loosen the jam nut on each adjuster, turn the adjusters in the direction that will shorten the cable housings to their minimum lengths. THEN remove the two screws and separate the upper housing from the lower housing, unhook the ferrules and cables from the throttle control grip and the lower housing, (remove friction spring, throttle friction screw and spring from the lower housing only if necessary), (only if and as necessary mark the position of the master cylinder assembly forward position and split line on the handle bars) (to be safe squeeze the front brake lever and place a 5-32 inch thick cardboard insert between brake lever and lever bracket and then release brake lever to hold the lever in this place to protect the brake switch from damage if the switch housing and the master cylinder get separated) (and only if and as necessary, loosen the two perch screws) move the lower switch housing as necessary and remove the grip.
To install the throttle grip apply a light coating of graphite to the handlebar and the inside surface of the upper and lower housings, (if removed, install the spring, throttle friction screw and friction spring in the lower housing) (and, if removed, attach the cable assemblies to the lower housing), (throttle control cable has a 5-16 inch fitting end and is positioned to the front of the lower housing. and the idle control cable has a 1-4 inch fitting end and is positioned to rear of lower housing. Install the throttle control grip over the end of the right handlebar, position the lower housing onto the right handlebar, engaging the lower housing with the throttle control grip, position the ferrules over the cable ball ends, seat the ferrules (with the cables attached) into their respective notches of the throttle control grip, install the upper housing over the right side handlebar and secure it to the lower housing with the appropriate two screws and hand tighten them, then align the brake master cylinder and perch assembly with the marks made prior to loosening them, and beginning with top screw, tighten the two screws to 108-132 inch lbs using a T27 TORX drive head and then tighten the upper and lower housing screws to 35-45 inch lbs. THEN point the front wheel straight ahead and WITH THE ENGINE OFF, adjust the throttle and idle cables by turning the adjuster in the direction that will lengthen the cables. Gently twist the throttle control grip to the fully open throttle position (fully counterclockwise) and hold it in this position and turn the throttle control cable adjuster counterclockwise until the throttle cam on the induction module (or carb) contacts the throttle cam stop, release the throttle control grip and turn the adjuster counterclockwise an additional 1-2 to 1 turn and tighten the jam nut on the throttle control cable adjuster. THEN turn the handlebars fully to the right and turn the adjuster on the idle control cable counterclockwise to lengthen the sleeve until the end of the cable housing just touches the spring within the cable guide. NOW check the adjustment by, with the throttle friction screw loosened, twisting and releasing the throttle control grip two or three times. The induction module throttle wheel must return to the idle position each time the throttle grip is released. If the throttle does not return to idle, turn the idle adjuster, shortening the cable sleeve until the correct adjustment is obtained, tighten the jam nut and slide the rubber boots over each cable adjuster. NEXT start the engine and with it idling turn the handlebars through their full range of travel and if the engine speed changes at all during this maneuver, adjust the control cables according to the foregoing procedure so that there is no change in the idle speed when the handlebars are rotated through their entire range of travel.
To remove the clutch or left side grip remove the two screws and separate the upper housing from the lower housing. Mark the forward position and clutch perch split line on the handlebars and then as necessary loosen the two clutch perch screws and move it out of the way so that you can access the grip end. If you want to save the grip take a small screwdriver with about an eight inch length and insert it into the grip, wiggling it to loosen the glue somewhat and then spray some brake kleen into the space under the grip where the screwdriver blade is inserted and wiggle and twist the screwdriver around to loosen the rest of the grip glue and pull the grip off. Sand down the handle bar area where the grip will rest and apply grip cement to the area and slip the grip on. If the left hand grip is patterned, align it with the pattern on the right hand grip with the throttle in the fully closed position, immediately push the grip completely onto the end of handlebar using a twisting motion. Do not hesitate when installing the grip or the adhesive may dry before installation is complete. Allow 6 to 8 hours to elapse at 70 degrees F to allow the adhesive to fully cure. If a newer non-glue grip is being installed slip it on with the flats properly oriented to fit with the switch housing halves when they are installed. Install the switch housing halves and lightly tighten the two screws and then orient the clutch perch to the previously made alignment marks and beginning with the top screw, tighten the screws to 108 - 132 inch lbs using a T27 drive head and then tighten the switch housing screws to 35-45 inch lbs.
Sep 20, 2014 | Motorcycles
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager?
If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience.
Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off.
Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart.
Good luck.
Jul 22, 2014 | Homedics Health & Beauty
Vidal sassoon vs505 disassemble
There is one Philips head screw near the top of the handle and there are four more behind the rubber on the handle grip. The rubber on the handle grip is attached to a curved plastic plate that has four clips that hold it to the handle, you have to pop the plate with the handgrip rubber off the handle to access the four screws.
Mar 23, 2014 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
How to move osim ucomfort massage chair
Heyy..!!
I have used brookstone massage chair. In my point of view brookstone massage chair is the best. It offers foot massages that can give great therapeutic massage which helps to relax the joints and muscles. It is the best massage chair in comparison to others. I like this massage chair..!!!!
http://massagechair.me/
Feb 08, 2014 | Brookstone Massage Chairs: Certified...
How do you take the brookstone massager apart--can't seperate it once screws out.
hit your **** and balls on it and you will get ***** ...sory i just wanted to post that sorry
Mar 09, 2012 | Health & Beauty
I need a replacement cord for the brookstone thera spa cordless massager
HELLO MEAD
I had a Theraspa cordless turbo massager that eventually stopped working but I kept the charger. It still works because I've used it for my replacement massager.
If you're still interested, would $10 be reasonable (plus shipping cost)?
I have an e-bay account and I can sell it to you through there if you want.
Let me know if/how you'd like to proceed.
JK
Nov 21, 2011 | Brookstone Theraspa Turbo Massager
NEED TO REMOVE DRIVERS DOOR PANEL ON A 2006 NISSAN 350Z
I did this myself before:
Removing the Door Panel
The first thing to do is remove the tab in your door handle that covers the screw (using the flat head screw driver), which secures the handle and window/lock switches to the door panel. Using the Phillips head screw driver, remove the screw. Now, remove the door handle and locate the tabs securing the wire harness for the door locks & power windows. Using the flat head, push down on the tabs and pull the male end out of the wire harness with your other hand. You can now locate 2 of the 3 bolts/screws that secure the door panel to the door.Using the 10mm socket, 3′ extension, and the 1/4′ drive socket wrench – remove the bolts/screws. Located behind the interior door handle is a plastic covering with a hole cut in it, that goes around the rubber piece that is there to stop the handle.Use the flat head screw driver to remove that plastic piece. Behind that piece, you will find the 3rd and final bolt/screw that secures the door panel. Using the 10mm socket, 3′ extension, and 1/4′ drive socket wrench, remove the bolt/screw. At this point you can pull the door panel off by hand.There are only tabs holding it on now, and they all will pop off. Now on the inside of the panel, you will need to locate the backside of the interior door handle. Remove the cables that operate the door lock, and opening mechanism. No tools are required for this step. Now you have the metal door panel, which is secured by 11-12 bolts/screws around the boarder of the panel.Locate the wire harness for the window motor in the upper right corner of the metal door panel. Using the flat head screw driver, disconnect the wire harness.After removing the panel, you will need to push the rubber grommet through the panel – the wire is attached to it. There will also be two white tabs on the backside of the panel that secure the female end of the window motor wire harness to the panel. Using your fingers (or pliers) pinch them, to remove the harness.
At this point, you can remove the 11 – 12 bolts/screws that are holding the panel to the door.The panel will not fully remove, but will come off a little bit. Now for the gold colored bolts/screws and nuts.Three of the bolts/screws are what secure the window motor to the panel.The other two bolts/screws, and the 2 nuts hold the brackets that hold the glass in place.there is one of these bolts/screws, and one of these nuts on each bracket (on each side). Using the 10mm socket, remove all of the bolts/screws.The Nuts are a 12mm socket; remove them as well. The panel should now come off, and the motor & guts of the door, will be revealed.
Apr 14, 2010 | 2005 Nissan 350Z
Health & Beauty Logo
116 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
