Question about Tricity Bendix AW1000W Front Load Washer
Need a drain pump for a WDC 1025 Bendix washer dryer combo. Any suggestions? Canada, Montreal or Toronto area prefered, but any will fine. Thanks.
2 Suggested Answers
nanbuenbrazo
  • 553 Answers
SOURCE: Where can I purchase parts (pump) for A Bendix WDC
better go dirctly to Spendide and get a new motor, they will give you warranty to it so you don't have to worry, other than buying it to other supplier , you might be able to get cheaper one but more likely it is refurbish and no assurance if it will last long
Posted on Nov 05, 2009
I am planning to buy a new home and i need to know the details of mortgage rates in Toronto, Canada. So anyone can help me?
Have you contacted a realtor in Toronto? Any of them would know the local conditions much better than anyone outside the area.
Jun 17, 2013 | Office Equipment & Supplies
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Is there a reset button on Frigidaire stackable washer/dryer combo. Dryer will not come on, washer works fine. thanks
Sorry to read about your problem.
Sorry no reset switch.Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 25, 2010 | Frigidaire Washing Machines
My little boy put my bosch exxcel washer/dryer on to dry for 2hours and then switched it to drain and then turned it off, now its stuck halfway through drain and the door wont open.
i have never worked on this type of washer dryer combo, but just from experience if a washer will not unlock and it keeps trying to drain it is either there is enough water in the unit to trip the pressure switch and the pump keeps trying to drain, means there is a blockage normally in the pump, blocking the pump, or blocking the pressure switch tube. clean these out and unit should work fine. if you arnt tech savvy , call a professional and be prepared to pay.
Nov 24, 2010 | Bosch Washing Machines
Hi, I have a bendix combo washer/drier WD1054. It's been working fine - until I inadvertently left the drier function on when doing a (too) full load. I got it to stop after a bit and thought all was OK....
Welcome to Fixya.
I`m not entirely sure if the component I`m thinking of usually has any effect on the spin, but it could be I just don`t remember. Anyway the thing I would direct you to look for is a thermal fuse.
All these unit`s ( Bendix, Kariba, Splendid, Equator etc. ) have at least one on the heater/condensor housing ( have to remove the top ) while some of the older unit`s have two.
**Safety first...turn off your breaker at the service panel preferably or unplug the unit first**
Remove the top and identify on the condensor housing the thermal fuse **see image below** and with a multimeter ohm it out.
This is not the actual bendix thermal fuse, just an image of what it will look like. I don`t even know where to get parts anymore, I used to get them from a gentleman in Calgary, Alberta, Canada by the name of **** Blanchard, but I no longer have contact info for him and I rarely work on these any longer.
If this fuse is open the heater will not function but it may also be tied into the spin cycle, but I don`t think so to my memory, unless it has the second fuse located on the harness going to the motor.
You`ll need to remove the back panel as well to trace the harness to locate the second fuse...if present at all, but the fuse used to be located near the motor at the connections.
Let me know how you make out, I`ll watch for your reply in this post.
good luck.
macmarkus :)
May 08, 2010 | Tricity Bendix WDR1040W Front Load Washer...
LG Washer/Dryer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Bendix washer dryer 1054
the brushes need replaced in the motor by the sound of it
Feb 24, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
74 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
