E5 what's meaning? In mitsubishi kerosene fan heater (KD_CX35AX)
2 Suggested Answers
  • 674 Answers
SOURCE: Kerosene garage heater (Desco) fan
Remove the top from the heater and clean the flame sensor. It should be the photo eye type. Remove it from it hold and clean inside with soft cloth or cotton swab with alcohol. If this doesn't help, let me know what you find. nitensheaterservice@earthlink.net
Posted on Jan 11, 2011
How to replace wick for Everglow PT-E5 kerosene heater
The procedure is about the same on all kerosene radiant heaters:
https://www.youtube.com/watch?v=HBTY-KL5oRo
good luck
Dec 15, 2017 | Heating & Cooling
Cant get my electric kerosene heater to light
Could the fuel be too old? I would recommend dumping the fuel in an outdoor firepit and burn it up. Use an inexpensive "Turkey Baster" to suck it out of the tank. Then put fresh kerosene in and try it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 01, 2017 | All-Pro Kerosene Garage Shop Heaters - All...
My heaters fan will not start, and the cercut breaker keeps opening.I thinking it needs a new fan motor
You are probably right, but there are 2 other possibilities. 1. the air pump rotor could be shattered, therefore binding the motor 2. the fan blade could possibly be binding (this happens mainly after storage periods....varmit nests)
All Pro Reference sheet
Aug 13, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene garage heater (Desco) fan starts, burst of kerosene, and the heating element is red. Within a few seconds, heater stops abruptly. Email address: p.s.stohr@sbcglobal.net Thanks for your help.
Jan 11, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My kerisene heater turns on for a few minutes than the safty braker kicks out
check the fan their are very little parts that would cause that the main one is the fan
Sep 12, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Reddy heater cuts out after 30 seconds
this problem is common with this type of heater and usually means that the fan is not pushing enough air over the heat exchanger and is tripping the high limit switch.check the fan
Dec 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
