Hi will a TNPA5351 AF SC Board interchange with a TNPA5351 The Model of the tv is TC-P46ST30 Thank You
alpug
  • 1961 Answers
SOURCE: Hello, I have a Panasonic
have you already checked the power supply section sir?power failure are often cause by a faulty capacitors at the power supply section.have a close look at the capacitors if you notice a deformed/bulging capacitors replace it and also resolder the components at the power supply board..
let me hear from you.
Posted on Mar 24, 2011
bobhifi
  • 635 Answers
SOURCE: I just bought Panasonic SC-PT480P-K
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Posted on Apr 02, 2011
bugoy31
  • 1238 Answers
SOURCE: i have replaced the p board and sc boards in this panasonic tc-p50s30 viera tv and still have the 7 red blinks? what else can be wrong?
7 blinks is indicate for faulty power supply however if you already replace it the possible problem is on main board..
Posted on Jun 07, 2012
gopakumarg43
  • 75178 Answers
SOURCE: tc-p60st50
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 26, 2016
gopakumarg43
  • 75178 Answers
SOURCE: Panasonic tc-60s30 no power blinks 7 times ,i disconected ribbon from sc board and power now iam getting 8 blinks i though if i get 6 its the sc board but iam getting 8 ,moms tv trying to fix it
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Posted on Feb 23, 2017
Hi just installed a new sc board #TNPA5351 AF and the old # was TNPA5351 will the part numbers interchange thank you Terry
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 30, 2016 | Panasonic Televison & Video
Panasonic Plasma TV TC-P50S2 10 blinks
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Sep 11, 2016 | Panasonic Viera TC-P50S2 50" Plasma TV
??How to fix a PANASONIC PLASMA TC-P60UT50
Could be the SC, but also might be either the SU/ SD causing the SC to go into protect. Pretty easy to determine, if you look at the SU SD and see any holes or burn cracks that would be the problem. Let me know if this works or can help further.
Apr 13, 2016 | Panasonic Televison & Video
What would cause sound but no pic on a Panasoniv LED TV?.
Back-light problem.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 06, 2014 | Panasonic TC P46ST30 - 46" VIERA ST30...
I have replaced the p board and sc boards in this panasonic tc-p50s30 viera tv and still have the 7 red blinks? what else can be wrong?
Jun 06, 2012 | Televison & Video
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Mar 07, 2011 | Panasonic SCPT480 Theater System
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
My panasonic 46 inch plasma tv has no display, the red light turns on but no picture, then after a few seconds the redlight turns off
i have the same problem on my tv and i call to bestbuy since the tv is only 2months so still on the manufactures warranty the problem is SC Board shorted, and they replaced the sc board.
Dec 27, 2009 | Panasonic TC-P42U1 42 in. Plasma HDTV
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
