Question about Cooktops
I have a EGG6345NO Hob and the igniters continue sparking so I have to turn the main switch off to stop it sparking,leave it for a while and turn it back on and on sometimes it stops it sparking.
  • 1314 Answers
SOURCE: All five ignitions clicking rapidly
yes is safe you probably got the ignighters switch's wet if one is wet will cause all to fire after awhile they dry and return to normal
Posted on Jan 10, 2008
  • 4 Answers
SOURCE: automatic ignition 'clicks' and 'sparks' non-stop
switch and spark module,
Posted on Jan 20, 2008
Eddie Rentas
  • 59 Answers
SOURCE: hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
SOURCE: Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Posted on Nov 15, 2008
  • 3093 Answers
SOURCE: My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Posted on Jan 16, 2010
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Duvalli GHG604B gas hob ignition problem. Ignition has stopped working. Everything is clean and dry. Power and fuse is O.K. I suspect the spark generator unit, but how can I test?
If you know the power and fuse is ok, and none of the knobs will turn on spark, the only thing left is the spark module. The switches would never all go out at once.  Good luck
Jan 07, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Sparking ignition
switch Is stuck in on position
Apr 15, 2008 | Tecnik 27 in. TKH3515SS Gas Cooktop
Gas hob ignition
1) try leaving it off for a while to see if the ingition box needs to reset
2)when you turn on the burnner does the ignition start by itself or do you have to "ignite" the burnner yourself?
3) if oyu have to ignite the burnner yourself, try using a bbq lighter to see if the gas has gotten to your range yet.
4) if no gas present, there is ussually a reset in the regulator. it needs to be reset if it gets low on pressure. you need to have the lines connected and then turn on the gas AND then the appliance. if the appliance is turned on before the gas in turned on the rest will pop.
lets us know what happens :)
Jan 30, 2008 | Cooktops
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
93 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
