Question about DeLonghi Coffee Makers & Espresso Machines
I have a delonghi perfecta and it seems like the coffee grinder is stuck in the down position. I am unable to get the drip tray to go back in. How do I get it go back up?
  • 2039 Answers
SOURCE: Drip Tray and Container for coffee stuck
the only thing would our drip tray is not properlt install and is jamming the rest try to move in and out the drip tray i am sure you already try it but it about the only thing that can hold the rest take our time dont force it good luck cheers
Posted on Jan 20, 2008
mirran
  • 515 Answers
SOURCE: Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Posted on Jul 26, 2008
EwingElect
  • 276 Answers
SOURCE: I desperately require an User Manual for a
try http://www.delonghi.com.au/support/instruction_manuals.asp?group=&mst=contain&ms=esam5500&dst=&ds=
Posted on May 26, 2010
SOURCE: I have the EAM3200 coffee maker and it seems to be
I have the same issue. I have tried replacing the O-rings in the water heating element and the steamer, and it still does this. For a temporary fix, try running the steamer for about 30 seconds, or until it is running "full steam", and immediately make your coffee. This has worked for my machine for the last 4 months. It is used about 5-10 times a day at my work, and this still is working. I believe the issues is it is losing pressure somewhere, and the water cannot travel through the infuser. I have taken apart my machine more than 10 times, and I still cannot find out where the pressure loss is. I know this is a temporary fix, but it will work until something more permanent can be done. Hope this helps!
Posted on May 27, 2011
mc1bean
  • 3053 Answers
SOURCE: makes funny noise when I try to grind coffee and
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Posted on Jun 13, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Hi - the machine works fine except that it leaks into the drip tray and kicks beans out, sometimes onto the floor. I have lots of tools and feel good about taking it apart, but need to know what parts...
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Sep 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Pressing the green button to make coffee. machine made strange noise and stopped. Now I can't remove drip tray and everything seems stuck.
Remove the power chord an plug it in again. This shoud seht the machine into starting position.
For details see www.cofffeemakers.de
Regards Fred.
Jun 26, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Keeps saying fill beans container when already full
The machine understant that there is not any beans in the container by the mesuring how easily the grinder motor rotates. If there is not any beans in the grinder motor rotates freely. In your case means that the beans from container are blocked to enter down to the grinders disk plates or they partialt enter, so the motor runs more freely and machine understant that there ae not enough beens. So you need to remove the beans and container and by the use of a vaccum cleaner remove all remainings from the grinders entrance and funel. You can also use a brush to remove any coffe oils and remianing so the bean can easily slide inside the grinder.
Jun 25, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Locating manual as coffee machine is unable to select appropriate grounding for coffee
There seem to be a number of different sub-models of the ESAM5500 line of superautomatic coffee makers.
You can see a list of all of the user manuals for these sub-models here:
http://web1.dlservice.org/dlservice/ext/delonghi/cercalibretti.php?cerca=ESAM5500&submit=Search
Good Luck!
Dec 28, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My delonghi esam5500 coffee bean grinder part is not working. seems to be blocked, can see beans moving when it goes to grind but no beans are taken in and it comes up with fill beans compartment? what...
In our case we were lucky. Grinder was blocked by the beans. This is what I have done with our Delonghi 5400. It looked fiddly but was quite simple really. I started from the back panel. Once back panel was removed I had access to 4 corner screws that remove both side panels. Now that give me access to 4 corner screws that hold top of the machine. I l also had to unscrew 5 screws that hold coffee container in place. 4 are visible once the coffee beans container is open, but the 5th is hidden in the middle of adjustment arm with a black cap on top.(adjusting how fine you grind). I used small sharp screwdriver to lift the cap. Once all are out I removed the top of the machine and then the funnely coffee container too. That exposed grinder assembly. Top of the grinder is actually loosely sitting in the lower part of grinder. Twisting it counter clock should release it I Think. Our was not budging, and I had to completely remove the grinder and detach motor but that is quite obvious too, and probably not needed. I just wasn't sure what I was doing. Our machine was out of warranty so... Would be nice if we had some schematics.
Nov 26, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi 3200
it can be 2 things. Sensor is burned through or the grinder itself is burned throuh.
Open the machine up and test the grinder as that will be the easiest.
Jul 27, 2008 | DeLonghi Caffe Nabucco BCO70...
Jan 20, 2008 | Saeco Royal Exclusive 30153 Espresso...
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
