Question about Refrigerators
E 10 code?
Uline refer/freezer gives me E10 after procedure of holding both arrows down etc
  • 552 Answers
E10= Top drawer open
Posted on Dec 09, 2016
My Frigidaire refrigerator is showing the code 5c 5b on the front panel. What do this mean
Hi Juanita,
I'm not sure what the 5c code is however the 5b code means "Sabbath Mode" (Sabbath Mode is a feature that disables portions of the fridge and its controls in accordance with observance of the Sabbath and religious holidays within the Orthodox Jewish community)
You need to press and hold the arrows ("?" on freezer temp and "?" on refrigerator temp) to remove it, if the arrows are not lit up, press them anyway to try and get the fridge out of Sabbath mode.
Hold down both arrows for ten seconds to get out of Sabbath mode.
If that does not work, unplug the fridge for 10 minutes, plug back in, and try once again.
Edit: On newer models the press points are different: Sabbath mode is turned ON and OFF by pressing and
holding "Control Lock and Power on/off buttons" for five seconds...
Hope this helps.
Oct 11, 2017 | The Computers & Internet
My brother dcp 1510 is telling an error massage "replace the toner cartige"i have changed toner ;try to reset but i cant please tell me the exact reset code and procedure .
Hi try this press menu button hit down arrow until u see info on display press OK button hit down arrow until u see reset drum on display press and hold OK button until u see reset on display press start button press-up arrow until u see the value 10 press OK button on display should read accepted press stop until the main menu appear on display.......good luck
Jun 10, 2016 | Brother Office Equipment & Supplies
Freezer not defosting
Good Afternoon Friend,
I understand that your Electrolux freezer, model# EW23CS65GS, is not defrosting and causing your freezer temperatures to raise as well as not produce ice. I suggest putting your freezer into a manual defrost cycle. You can do this by pressing and holding down the, refrigerator temperature up and down arrows simultaneously for 5-10 seconds. You will see a "D" appear on the freezer side display and an "F" on the refrigerator side. Let this run for 30 minutes. After the 30 minutes press and hold the refrigerator up and down arrows again. If you do not notice any change, try resetting your appliance, by either unplugging it or shutting the power off at the circuit break, for 3-5 minutes. Once power is restored, give your refrigerator 24 hours to run through its normal cycles. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
May 25, 2014 | Electrolux Ew23cs65gs, Side-by-side...
I have brought a universal tv remote a DIGITECH AUDIO VISUAL I can not find the code for a LG. AKB69680403 can any body help me !
Hello David,
With out the part number of the Digitech remote it will be very difficult to try to help. You can try this procedure that I found in a old post.
Try the autoicon1.png code search. Switch on the device > Select the device key to program > Hold the green "Set" button for 3 seconds > Press "OK" at "Setup" > press "OK" at "Code Se[t]" > Press the down arrow to highlight "Auto" > Press "OK" > Aim at the device > Hold the down arrow for 2 seconds > Press the "OK" button when the device powers off.
I can not be certain that this procedure will work with you unit or if it will give you access to the full control set of the LG TV. If that does not help come back and post further information
Nov 26, 2013 | Televison & Video
Kenmore Error Codes OF on an upright freezer
Which model Kenmore freezer do you have? For the Kenmore 253.28462801, made by Frigidaire, the OF code means that the freezer is in Demo mode. You need to turn off the freezer by pressing the UP arrow until the unit reads 10. Pressing the UP arrow twice more within 2 seconds brings the "0F" code.
Press the Down arrow twice within 2 seconds to turn on the freezer. (The display will read -10.) Use the arrows to set the desired freezer temperature.
If your freezer was made by Frigidaire, you can usually find the manual on their support site: . Other Kenmore appliance manuals are often available from Manage My Life, . Some paper copies of the manuals can be purchased from the Sears Parts Direct, http://www.searspartsdirect/ . Note: you will need Adobe Reader or a similar program to read the manual from Frigidaire or Manage My Life.
I hope this helps.
Aug 15, 2013 | Washing Machines
I have a service code CS541 for a Savin 2522 - I need to repair it
Ricoh copier service code SC541 refers to the fuser assembly having a problem.
Sometimes they code can be temporarily reset, however, it will eventually come back
and not go away!
While the printer is on do the following:
  1. Hold down both of the arrow keys for 10 seconds
  2. Press ENTER
  3. Select Option 2 for Engine
  4. Choose 7 Data Log
  5. scroll down to 7807 and execute it. click OK
  6. press the escape button until you get to the engine option
  7. then select option 3 to end
  8. restart the printer by pressing the power button.
If the above does not work, repeat the procedure but instead of 7807 look for SC calling, something like that, and reset the whole thing.
The reality is that the problem is fixable though, and do not need to purchase a new fuser, after clearing the code, the printer should work fine again
Jan 31, 2011 | Savin 2545DP Black and White Copier
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Multiple lights are lite when running a cycle....can't run certain cycles (bulky items, whites etc) spin light continuously blinks. have tried unplugging and restarting with no results
I feel you may have a Control Board issue. I would see if the Control Board will let you into Service Mode. If it does I would read the Diag code blocks 1 thru 40. The block only show up when an error event has been logged.
Bottom line I see no easy way out without least swapping out the Control Board for a start point.
You will need the FAV6800A/FAV9800A Service Manual to get started. See page 17 of the SM TO READ THE Diag codes
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Here is a quick start if the Control Board will let you into Service Mode;
To enter Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00.
From the Service Manual;
Display Diagnostic Codes
The diagnostic code display can be toggled on and off from Service Mode by pressing the Wrinkle Control key. The display will show a “d”. The diagnostic codes can be viewed by using the Set Delay Time arrow keys. The Set Delay Time down arrow key will cycle down the list one code at time each time it is pushed. The Set Delay Time up arrow key will cycle up the list one code each time it is pushed. The first time the Set Delay Time down arrow key is pushed, the newest code will be displayed. A code generated during or after the current cycle will be displayed with the rightmost dot “.” turned ON. Access Other Features While a diagnostic code is displayed, if the Normal
If you decide to give it a try jot down the code blocks and toss them back to us for review.
The Control Board p/n 25001217
Another vendor Clothes Washer Control Board - 25001217
Good Luck Rich
Dec 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Uline under the counter two drawer refrig seems to be running very hot, with ER blinking on temp gauge inside top drawer
Er means that somthing is wrong. It could be a temperature problem that caused it. Does it beep at all. That is a alarm for the door being open. You may need to check the magnet on the door and the reed switch on the wall. Upper left for the top drawer. and on the bottom is on the grill and door. Normally this is something I would ask for a tech to look at. But if you feel confident to try this I can get you into the program to see what its telling us. Now hold the up arrow and at the same time press and release the light bulb 3 times. Then release the up arrow last. If you did this right then you will have a 0 on the display. Yes, Then up arrow until you get to 3. Then press and release, It should give you a number. E# ? Let me know what this is. You may have a couple so write down all of them.
Now after you got the number then just push up arrow until you get to 99 then press and release the light bulb to go back to the refrigeration cycle.
E3= bottom drawer open to long
E1 = Thermistor #1 open
E5 = 10 degrees to warm E6 = 10 degrees too cold E7= Thermistor 2 E8=Thermistor 3 E9 =Thermistor 4 open thermistor 1 located top drawer Thermistor#2 I/M or evap if no icemaker
Thermistor3 is located in freezer or base if no freezer thermistor 4 is drain pan
Hope this helps
Jul 22, 2009 | U-Line Refrigerators
My Uline ? Model U-217RS-O is 14 months old. The problem I have is the temp will not go below 38. What can I do?
Ok On the display hold the up arrow for 5 seconds then let go. It will tell you the temperature. Do you have and er at the display? Is the unit outside? What is the temperature(ambient) around the unit? If you hold the up and down arrows together for 5 seconds then release it will show you thermistor temperature for 2,3, and 4 You should only get 2 to give a temperature. 1=refrigerator temp and 2=evaporator temp.
Make sure the condenser is clean from dust.
Jun 28, 2009 | U-Line ?chelon 2175RB-00
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
