My smart drive 051 won't start. All the buttons and lights seem to be in order. The lid microswitch seems to be OK.
I pressed the temp-up and power buttons as per one of your posts and got warm/medium level/fast spin lights on, but I do not know what that means. In the past, I've removed the control panel and jiggled the connections and it's always started, but not this time.
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
  • 713 Answers
SOURCE: Fysher and Paykel smart drive 051. takes ages to
Hi just read your posting.Now what water temp have you selected for wash?Is it cold, warm, or hot?Sounds like a water flow problem to me.The water valves on your model of machine sometimes sound like they are filling correctly but they only let a little bit of water in.How long does it take to fill your machine and start agitating when you have selected low water level?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Fysher and Paykel smart drive 051. takes ages to start. cold water flow seems ok. takes 2-3 times longer for full cycle. sometimes stops and hot water light flashes. yours, jagrat.
Aug 18, 2010 | Fisher and Paykel Washing Machines
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Fisher Paykel Smart Drive 051 washing machine will not start. All other buttons working as normal (can select wash cycle length, temp, water level, etc). Have had no previous problems. When diagnostic mode...
Peace Friend,
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 31, 2008 | Fisher Washing Machines
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Washing Machines Experts
