Question about Refrigerators
Hi the fridge door inner has been very hot ,strong smell of burning but fridge is working and door no longer hot now.
  • Refrigerators Master
  • 10,045 Answers
The defrost timer is not shutting off the heat strips in the cabinet. The smell is the fiberglass insulation overheating. Replace the timer.
Posted on Dec 06, 2016
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Refrigerator smells horrible , but there is NOTHING spoiled in it.
You might have something smelly in the defrost drain pan. The easiest thing to do would be to take the back off the fridge and see if the defrost drain pan smells bad...if so just clean it out with soap and hot water. don't use anything too strong smelling to clean it though, you don't want your fridge to smell like bleach or pine sol.
Good Luck!
Sep 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
There is a strong chemical burning smell coming from the fridge/freezer but it still seems to be working ok at the moment, the light is on and still feels cold, any ideas what this could be?
if the smell is very sweet something like peardrops, could be poystyrene packing. check for cable chaffing where it enters cabinet.replace mains cable completely. if mains cable outer cover is getting too hot it will smell as above WARNING polystyrene gives off cyanide gas over 120c/when burning do not inhale(only had 1 freezer melt in 30 years it was set on purpose)
Feb 07, 2010 | Refrigerators
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Very Strong Odor When Refrigerator Runs
Without looking at your fridge I would say the strong rubber smell is the heater element has dust on it or the heater contactor is closed and the heaters are staying on. Either way it would be good to get it checked out. I cannot think of anything else that would make a rubber burning smell.
Jan 23, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
