Question about Tools & Hardware - Others
Is the lathe shaft and bearing readily avaialable Model 55-4507-2 SER.no WO 43053
4 Suggested Answers
  • 188 Answers
SOURCE: reddy 110000 btu fan motor needs front bearing
You may want to contact Master Parts, they may not have the bearings. However, they may have that motor at a reasonable price. You can contact them at 800-446-1446 or online at www.masterparts.net. I hope this helps you.
Posted on Apr 09, 2009
frankzcomput
  • 268 Answers
SOURCE: How do I replace bearings on an Atlas model 7122
You have posted in the computer repair section of the site. Please take the time to repost in the correct area to get the best response.
Posted on Jan 29, 2010
james3751
  • 614 Answers
SOURCE: I need a blower assembly for weatherking model#RHCF-100ZK
Go to www.americanhvacparts.com . You can buy bearing and a shaft from any HVAC supply house. They are standard bearings and shaft. Rus
Posted on Mar 17, 2010
Where can find parts such as an agitator and wringer bearings
Bearing for most machinery are not custom made but 'generic' precision components which can be got from a good engineering maintenance supplier.
Other parts can be made withy lathe or mill..
New castings can be made using the 'old part' as the basis of a 'mould'
You need to measure and list the vital parameters with a vernier calliper guage to a thousandth of and inch... The mersurements will always be to a 'round' figue... but if foriegn MAY be metric...
a) Type .. (Probably 'ball' rather than roller or cone)
b) The outer diameter
c) The width
d) The inside (shaft diameter)
More modern bearing can be better than the original as also be 'sealed' ..
Example: http://www.ebay.com/itm/Sealed-Ball-Bearing-R12-2RS-3-4-x-1-5-8-Bearings-/360189258862?pt=LH_DefaultDomain_0&hash=item53dcf3ec6e
Mar 15, 2015 | Maytag Model E2l Vintage Wringer Washer...
Blows breaker and groweling noise
It sounds like the motor is bogging down due to bad bearings or something is making the shaft too hard to spin. Make sure all the spindles are free. If its happening under load, make sure the lathe gets up to speed before trying to make any cuts.
Oct 18, 2012 | Ammco Combination Disc/Drum Brake Lathe
How do you check the cam/shaft timing on a 16 HP Kohler engine?
Go to http://www.kohlerengines.com/manuals/landing.htm and enter your engine model number as instructed on that page. Kohler generally has service manuals avaialable on their site.. As an example, there are 2 service manuals for 16HP vertical-shaft engines available there (Courage and Magnum series) and 3 service manuals for 16HP horizontal-shaft engines (K, Magnum and Triad series).
Jul 19, 2012 | Garden
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
Buy Sell Used Brake Lathes Brake Lathe Parts
Dec 16, 2010 | Ammco Combination Disc/Drum Brake Lathe
MY AMMCO BRAKE LATHE IS CUTTING EVEN,BUT LEAVING SMALL GROOVES
The problem isn't clearly explained. but the main shaft bearings go bad after awhile and it's one day thier good the next job their bad.
May 13, 2010 | Ammco Combination Disc/Drum Brake Lathe
Mar 17, 2010 | Heating & Cooling
How do I replace bearings on an Atlas model 7122 wood lathe? Do I use a gear puller to force the shaft out of the housing?
Jan 29, 2010 | Kano Technologies Atlas (K752HCDR) DVD+R...
Reddy 110000 btu fan motor needs front bearing , shaft id fine i took motor apart by grinding weld off of end bell. i am a motor repair expert, retired do not have accses to a lathe or i coud make a...
Mar 06, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Tools & Hardware - Others Logo
29 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
