Question about Camping, Backpacking & Hiking
Multi tool flashlight by outdoor
Install batteries
Temperature in/out 911711; changed batteries on bothe indoor and outdoor units. Outdoor temp not registering on indoor unit.
  • Remove all batteries
  • Install batteries in outdoor unit and allow it to initialize and begin sending data.
  • Install batteries in indoor unit. You should see outdoor temperature displayed
If not, either unit or both may be defective
Aug 07, 2017 | Measuring Tools & Sensors
My 6yo NatGeo super weather station has quit transmitting outdoor temp & humidity info. The display is present and correct for all other categories. Changed batteries, no help. Any ideas?
  • Install batteries in transmitter and wait for it to begin sending data
  • Install batteries in receiver. You should see temperature and humidity displayed
Jul 18, 2017 | Measuring Tools & Sensors
Changed batteries and now cannot get an outdoor reading.how do I fix this?
  • Make your way indoors at a leisurely pace. This allows the outdoor unit to initialize and begin sending data
In cold weather, the outdoor temperature display may disappear due to frozen batteries. At the moment my reading is - - because it is around 40 deg. F. However, in a day or two when the outdoor temperature reaches 50 deg., the outdoor temperature will be displayed again. All in all, rather whimsical.
Jan 22, 2017 | Measuring Tools & Sensors
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
Battery is showing 13.5 volts on multi-meter but motor is not coming up to full speed turning light is ok. Joints. Wiring looks okjust not as quick as it was.6 weeks ago.chris
your battery may show the 13.5 volts but it is the amps you need to worry about in this case.you will have to have the battery load tested,sounds like the battery has a weak cell or a dead cell.
May 20, 2010 | Sport & Outdoor - Others
Camping, Backpacking & Hiking Logo
119 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
