My unit flip pages automatiquely ... is anything I can do
UNIT : KOBO HD
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
Opening the back of the Kobo model K107 what tricks are used to get it open to work on the unit
You won'r be able to see anything apart from a battery and some electrical components. You void the warranty if you open it up. Here you go. It will be the same for all. There are plastic snap tags.
Kobo Touch Teardown
Jan 18, 2016 | Kobo eReader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
How do I change my email address
You can change the personal information used with your Kobo account in your Account and Profile settings.
These details allow us to complete your purchases in the Kobo Store, or let you opt in or out of Kobo email updates and offers.
  1. Go to kobo.com
  2. Sign in to your account with one of these options, depending on what you see:
    • Click the >Profile icon at the top right of the page, then click Sign In.
    • Click the >Menu icon at the top left of the page, click the >Profile icon, then click Sign In.
  3. Enter your username and password.
  4. Click Continue.
  5. Open your account details with one of these options, depending on what you see:
    • Click the >Profile icon the top right of the page, then click My Account.
    • Click the >Menu icon at the top left of the page, click the >Profile icon, then click My Account.
  6. Make your changes.
  7. Click Save. Your account will be updated to reflect your changes.
Feb 11, 2015 | Kobo 6" eReader Touch Edition
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
My computer tells me I need new usb drivers for my kobo touch. Anyone know anything about this issue?
go to this page : Extended driver Kobo
and scroll downwards till the and of the page and there u find a zip file download than and install it than it should work fine
Nov 25, 2013 | Kobo E-reader Touch 2gb, Wi-fi, 6in -...
How do i change font size on my kobo mini
while in a book, tap in the middle of the page, the second to last button on the bottom of the page - (looks like four directional arrows) then the bottom of the screen will change and you will now see a slider bar on the left with plus and minus sign- Tap on either to change the font size.
Jan 18, 2013 | KOBO, INC Kobo Mini
Media buttons along top, power button, power indicator, and mousepad lights lite up as soon as AC power cord plugged in, without having to press power button at all. Nothing else ever happens, HD spinning...
1) Unplug unit.
2) Remove battery from unit.
3) Flip unit over onto it's top, showing the bottom to you.
4) On most HP's, there's a small compartment where your RAM is held. This is in the almost direct middle of the laptop. It should contain either 1 to 2 small screws. Remove the screws.
5) The door should be able to pull up and it will expose your memory.
6) Remove the memory (there are two latches that hold it in place on the sides of it, spread the latches and lift up on the memory.. you might feel a little pressure.. it's okay.)
7) After removing the memory, flip the unit back over, plug it in and power it on.
8) The unit will beep a couple of times and shut back off.. this is a good sign.
9) Remove power cable again, flip unit back over and reinsert the memory.
10) Screw the memory cover back down.
11) Reinsert battery, plug power cable in and try to power on again.
good luck, hope this helps! if it does.. please rate for me ! :)
Mar 29, 2011 | HP Pavilion dv2120us Notebook
I just got a kobo lookbook "ereader" for
I had this same problem. My computer couldnt read thre Lookbook and I tried all my usb ports and different computers. Luckily i had another cable similar to the one the Lookbook came with and it worked. I guerss the problem was just the cable. I am more the satisfied with my lookbook now. I can drag and drop magazines and all pdf files into my lookbook. dont forget to re4start you computer
Best of luck and happy holidays
Dec 23, 2010 | HP Computers & Internet
k24674
jasbo
jasbo
