Question about Apple Computers & Internet
MacBook Pro took an accidental splash w/cranberry juice & water last night. Today it's a paperweight. I have AppleCare but no coverage for liquids. Any ideas on how to fix it WITHOUT paying Apple $$$?
  • David Giaimo Sr
    David Giaimo Sr Dec 05, 2016
    Don't say "Try a rice-filled bag!" This might evaporate the water portion of the spill, but the sugars will then concentrate on any components, potentially shorting out circuits. Thanks!
    Top Expert:
  • Apple Master
  • 8,211 Answers
All you can do if you know what you are doing is open it up and dry it out best you can..and hope for the best.
if it was on at the time there you are in trouble.
even if apple got it back i dont think it would do much good.
have you tried drying it out with a hairdryer or put it on a hot radiator .
Posted on Dec 05, 2016
  • David Giaimo Sr
    I would dry it but again, I'm worried the sugar in the juice will cause more damage! It was closed and asleep, and standing vertically on its right side, but I think the liquid leaked in through the left-side ports. Apple says they will repair it but might charge as much as $1,200 - which is what I paid for it when I bought it from Apple a year ago. Sheesh!
  • NOEL
    NOEL Dec 05, 2016
    if it came into my shop i would open it up and clean it out plus it would all be tested so you can see why it would cost so much to do.so again if you know what you are doing try it out if not dont touch it and take it to someone thats knows what they are doing.
  • 30 Answers
SOURCE: Macbook Leaking
This is a quite common problem.
This liquid is a coolant, when the mac works for many hours & heats up the coolant will start leaking out, it's not battery acid.
You better head to your dealer, I don't know what Apple are doing about it, but I sure hope they'll fix it.
Posted on Aug 12, 2008
Clearercape
  • 38 Answers
SOURCE: Macbook screen messed up
Hi there
Yep, I understand your concern.
The cheapest and quickest way is to get an external monitor.
You can pick up flat LCDs very cheaply these days. Even second hand ones on ebay.
The only down side is you cannot use the mac on the move.
I for instance have a monitor at work and at home. I just plug my mac into the monitor where ever I am.
The new monitors come with digital cables.
Good luck
Posted on Sep 08, 2008
SOURCE: APPLE MACBOOK
If you get the Apple logo with spinning lines underneath it but not getting past this stage then the hard disc is being seen but something is failing in the boot process, causing it to stall.
Most likely this is a case of incorrect file permissions which is easily solved.
There are 2 ways of doing it, depending on whether you have an OS X install disc to hand or not.
IF YOU DO HAVE AN OS X INSTALL DISC:
Insert the disc into the DVD drive, power on the Mac on after hearing the chime hold down the C key. This forces the Mac to boot from the DVD. After a few minutes you'll get a screen asking which language you wish to use as the main language; select English or whichever is appropriate for you.
On the next screen the Installer box will appear. Ignore this and instead on the menu at the top of the screen select Utilities -> Disc Utility. Once this has loaded select your hard drive on the left hand pane and then first click "Repair Disc" and once that has finished click "Repair Permissions".
Once these have completed successfully reboot and OS X should load up fine.
IF YOU DON'T HAVE AN OS X INSTALL DISC:
This is a bit more tricky. You have to boot into single user mode. To do this power on the machine, and after the chime hold down Cmd (Apple key) and S together. The screen will turn black and an a load of white text will start appearing and scrolling upward as the system loads. Basically this is what happens behind the Apple startup logo, only in single user mode rather than multiple user mode.
After a few moments the text should stop scrolling and you should see a prompt which looks similar to:
localhost: / root#:
Note that localhost is the name of your computer so will possibly be different to "localhost". At this point type the following EXACTLY including spaces, capitalisation and dashes etc:
/sbin/fsck -fy
now press enter, then type:
/sbin/mount -uw /
now press enter then type:
diskutil repairPermissions /
and press enter. It may take a few minutes to repair the disc's permissions, but once complete you should have the
localhost: / root#:
prompt again. Now type:
reboot
and hit enter. The system will then reboot and should boot into OS X without issue.
Posted on Sep 23, 2008
Kree8iv
  • 192 Answers
SOURCE: Coffee spilled on my Macbook
Hi. Was your macbook open at the time? If os, then the beverage may have gone deeply into the machine. There is some protection from a bit of the elements under the keyboard, but not waterproof protection. also speaker areas and between where the monitor meets the frame. Also the battery compartment and memory compartment are breachable as well. The service center will probably know moisture to a large degree has entered the chassis of your computer. I said probably because it obviously damaged the computer, hence the need for a service center. Coffee gets in there and really can create a problem. Especially if there was mild and sugar in it. Good luck to you. It may be OK. Pretty sure your hard drive is at least.
Posted on Jun 14, 2009
APPLESUPPORT
  • 70 Answers
SOURCE: my on board audio output stopped working last
Reset the SMC and PRAm and check.Update the OS also.Check with a saperate external OS loaded HDD.This can help the issue.If not then the issue is suspected with the logic board
Posted on Apr 12, 2010
Sideeffect cranberry capsule 500mg
Click on the GREEN Side Effects tab.
Cranberry is LIKELY SAFE for most people when taken by mouth appropriately. Cranberry juice and cranberry extracts have been used safely in people. However, drinking too much cranberry juice can cause some side effects such as mild stomach upset and diarrhea. Drinking more than 1 liter per day for a long period of time might increase the chance of getting kidney stones. Special Precautions & Warnings: Pregnancy and baby feeding: There is not enough reliable information about the safety of taking cranberry for therapeutic reasons if you are pregnant or mummy feeding. Stay on the safe side and avoid use.
Children: Cranberry juice is LIKELY SAFE for children when taken by mouth as a food or drink.
Aspirin allergy: Cranberries contain significant amounts of salicylic acid. Salicylic acid is similar to aspirin. Avoid drinking large quantities of cranberry juice if you are allergic to aspirin.
Inflammation of the stomach lining (Atrophic gastritis): Cranberry juice might increase how much vitamin B12 the body absorbs for people with atrophic gastritis.
Diabetes: Some cranberry juice products are sweetened with extra sugar. If you have diabetes, stick with cranberry products that are sweetened with artificial sweeteners.
Low stomach acid (hypochlorhydria). Cranberry juice might increase how much vitamin B12 the body absorbs for people with low levels of stomach acid.
Kidney stones: Cranberry juice and cranberry extracts contain a large amount of a chemical called oxalate. In fact, there is some evidence that some cranberry extract tablets can boost the level of oxalate in the water works by as much as 43%. Since kidney stones are made primarily from oxalate combined with calcium, healthcare providers worry that cranberry might increase the risk of kidney stones. To be on the safe side, avoid taking cranberry extract products or drinking a lot of cranberry juice if you have a history of kidney stones.
CRANBERRY Uses Side Effects Interactions and Warnings WebMD
Dec 27, 2016 | Reaction Watches
Cranberries
Frozen cranberries work just as well as fresh in cranberry sauces and relishes. And if you freeze them using the method I'm about to share, they will remain loose in their freezer bag or container rather than clumping together. That's important because it means you can take out exactly the amount of cranberries you need for a recipe.
Here is the best way to freeze cranberries:
  • First rinse the cranberries under cold water and let them drain in a colander. Sort through the cranberries and remove any that are shriveled, mushy, or green. Compost or discard those. Also pick out and get rid of any stems.
  • Spread the cranberries out on a dishtowel and let them air dry for about 15 minutes.
  • Now spread the cranberries in a single layer on a baking sheet with sides, or on a dish.
  • Put the cranberries in the freezer, uncovered, for 2 to 8 hours. Less than 2 hours may not fully freeze the cranberries, but be sure not to leave them in longer than 8 hours or they will get freezer burn.
Jul 12, 2014 | Wine & Spirits
I have Macbook pro and spill water.It is now 6days and dying out.Very hard to remove battery as Macbook has 6-8 screws to remove batteryMac book is only year old.Is there any easy way to start without
Was it just water or was there any salt or sugar in the liquid water? Did you set the Macbook vertical ( so the water would not sit on the motherboard?
BTW: The first thing you should have done after water spillage was to remove power and the battery!
http://www.wikihow.com/Save-a-Laptop-from-Liquid-Damage
Feb 03, 2013 | Apple MacBook Pro Notebook
When I booted my Macbook Pro today, I could hear the hard drive being accessed, but the screen remained black. Have you heard of this problem before? Last night, it was fine and showed no symptons
yes this happens. you can try doing this: power down then power up whilst holding down command, option P and R all at the same time. press these after you hear the chime. hold until you hear the chime a second time.
May 05, 2010 | Apple MacBook Pro Notebook
There is a line going across the screen of my mac book pro. What can I do?
the lcd display has got spoiled... there is no way u can repair that cause the liquid pixels have leaked ... mm sorry buddy but u have a big bomb expense
Jan 12, 2010 | AppleCare Protection Plan for iMac/eMac...
My Macbook pro scree has flickered and gone
It's usually the inverter and not the backlight. You can replace it yourself, it's not that hard.
Fixya.com is a good place to get started. They've got really user friendly guides that will help you from start to finish. Check it out so you know what you're up against.
Otherwise a local Apple tech via craigslist is probably the cheapest route. Or Applecare if that's still a possibility.
Nov 21, 2009 | Apple MacBook Pro Laptop Computer with...
Garbage disposal spouting water after turned off
Hello, turn on the disposal without water and pour hot water into disposal. Be careful not to let it splash back on you! If this doesn't help you have to remove the drain and drain trap and clean them out. If you need more help let me know. Good luck.
Jan 23, 2009 | GE 24 in. Profile PDW7800 Built-in...
I can not open the full screen in my macbook
i can't be positive, but it sounds likely that your graphics card needs replacing. i'd give AppleCare a call - especially if you have an active AppleCare service plan for that machine - and ask them to help you troubleshoot the problem. they determined that my graphics card in my Mac Pro was kablooie right over the phone and made arrangements to send me a replacement.
the number for the AppleCare service and support line is 1-800-APL-CARE (1-800-275-2273).
hope this helps. good luck!
Dec 29, 2008 | Apple MacBook PC Notebook
Computers & Internet Logo
131 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
