Question about Gateway 7330GZ Notebook
Cd dvd player doesn't even show up on the computer.
    President:
  • 1,335 Answers
If you have checked the connections to the player and it is getting power, you will need to delete the CD/DVD driver that is installed and reinstall it. You can find the driver online. What is the manufacturer and model number?
Posted on Jul 20, 2009
    Scholar:
  • 151 Answers
Make sure the device is active in the device manager in control panel.
Also make sure it is connected properly e.t.c.
  • 453 Answers
If you are using Vista
  1. Click Start cd dvd player doesn't even show up on the - vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
If you are using XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
This should help.
I have compaq presario S2021a and it appears that the dvd/cd driver isn't loaded even though i have a place put them, it doesn't recognise it
Assuming it is beyond the warranty to have it fixed, you should be able to go the web site for the maker of your DVD/CD player and after selecting the model number you have, you can "download" the driver even if the device is not working.
Also, depending upon how old your system is you might just have to replace it. They are fairly cheap to buy either on-line or from an electronics store.
If you don't know the name of the device you have installed, go to www.belrac.com they have free download that will show you EVERYTHING that is in your computer by brand name. You can even print it out for your own reference.
If you want to install a new replacement unit, it really is easy. Instructions will come with the new device or even before you buy one, go to www.youtube.com and type in "how to replace a DVD/CD on a computer" and there will be a large selection of videos to give you an idea of how it is done.
Hope this helps.
Apr 04, 2013 | Extreme Networks (52021) Network Adapter
In my dvd player some dvd, cd do not run and shows unknown disc. please advice me how can tbis be cured thanx rakesh l singh
Try to use Lens cleaner,its available from electronics store, if it doesn't cure maybe your lens is old enough & need replacement
Sep 13, 2011 | LG DE9523P DVD Player
I have a 2005 Ford Freestar Van. The DVD player just quit working, appears it may not be getting any power to it. The manual doesnt have anything about the dvd player even being in the van. I was going to...
The manual shows several fuses for the radio/tape/cd players.
It doesn't show anything for a dvd player but i would think it would use the same power feed as the other. In thepassenger compartment take a look at fuse number 5 and 11 and 20. if they are all ok then in the power distribution box under the hood look at fuse number 56, 59 and 62. Fuse number 62 is the listed as the dvd fuse. However the systems use multiple fuses so that parts of have power all the time, Such as the clock and alarm systems must have power all the time in order to work.
Now not all of the fuses I have listed may be being used but these are all the ones listed for all the different sound systems used.
If all the fuses are good you may have to remove the player and look for a manual release to open it.
Jul 29, 2011 | 2005 Ford Freestar
I downloaded the firmware for my DVP3580 dvd player from the Philips website and unzipped it to a usb stick. It shows up on the stick as a VLC video file (VLC is a programme I normally use to watch...
You may want to load the update to a CD and try it. The web site should have good instruction on either load device. I had to go to my System Setup on the TV screen to make it work.
Jul 22, 2011 | Philips DVP3982 DVD Player
Dvd or cd shows loading but doesn't do anything else
The reading lense may be dirty or need replacing. Try purchasing a DVD cleaner (a CD with a small brush on it, e.g. http://www.amazon.co.uk/s/ref=nb_sb_ss_i_0_11?url=search-alias%3Daps&field-keywords=dvd+cleaner&x=0&y=0&sprefix=dvd+cleaner )
If this doesn't work then the reading lense may need to be replaced. I'd recommend taking the player back to the store and asking if they can repair or replace it for you.
May 07, 2011 | Televison & Video
My CD Player for a [Compaq] Presario V3000 hasn't been working. It worked fine less than a year ago, then it stopped working. My Computer doesn't show the CD icon any longer, not even Device Manager seems...
It will cost about $30 to buy a brand-new CD/DVD reader/writer.
Any computer-store technician can easily "manually" open your current drive, and remove the CD/DVD media.
Dec 14, 2010 | Compaq (120192-B21) CD-ROM Drive
Won't reconize disk in player
Well here is your resolution for your problem.
As you saying that when you insert any CD or DVD in Player its shows NO DISK.
Well Sometime what happen is if a CD contains are not compatible with Player than it wont work with it.
Or if you had burn that CD or DVD from your personal computer or laptop but it is not burn in proper format than also it wont work in PLAYER.
Well even if CD or DVD is having any scratches on it or it is Used uncounted enumerable times than also sometimes this things happen and it wont work in PLAYER.
Well before Inserting any CD or DVD in Player Just check the above mentioned points.
If everything is ok with the CD or DVD but than also its shows the same problem than get the CD or DVD cleaner liquid spray or even you can use Spirit to clean the CD or DVD and than Insert it.
After doing all this but if its shows no result in it than go to the company dealer and ask him to change the head of the player and you wont face this problem afterward for sure.
if you still have nay quarries regarding the same or any other you may reply me.
Naiven
May 23, 2010 | RCA DRC233N DVD Player
I can't watch a DVD +R on my computer only in a Samsumg dvd playe
it may be that your dvd player may not be able to read dvd+r discs. not all do ,please check your dvd player has the capabilities of reading dvd+r discs.
i.e have you ever watched a dvd+r before on your dvd player?
if it does try getting the model number of it.
May 19, 2009 | Computers & Internet
My player shows wrong disc to all discs
Use a Lens Cleaning Utility to cleanse the Lens of your Player. Lens Cleaners are available with all vendors of Computer.
Jul 05, 2008 | Coby TF-DVD7107 Portable DVD Player
Gateway 7330GZ Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
