I installed UAB 616 and have no sound? from speakers
Low diastolic pressure for what reason
That paper coined a new term, "isolated diastolic hypotension," which refers to a low diastolic blood pressure (less than 60 mm Hg) and a normal systolic pressure (above 100 mm Hg). Older adults who fit those conditions are at increased risk for developing new-onset heart failure, the researchers found.17 May 2015
UAB - The UAB Mix - Diastolic blood pressure: How low is too low? Low diastolic pressure for what reason Google Search
Dec 13, 2016 | Health & Beauty
My onkyo tx-nr 616 suddenly stop working, error pls check sp-cable, what could be the reason.
Either voice coil to the speaker is shorted, or the audio output section circuit to your receiver has shorted component/s at it. Disconnect all the speakers from the set, and check whether it shows any warning error like this. If dhows, the fault is within the receiver itself. If does not show any error message, switch off the set, and connect the speakers; one by one at a time, and try to find out which one is faulty. Be remember to switch OFF the power to the receiver, each time when one speaker box is connected. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 26, 2014 | Onkyo Audio Players & Recorders
How to repair
Your speakers may be drawing too much current. Borrow someone's smaller (lower wattage) speakers and test it with only those plugged in.
Sep 06, 2014 | Kenwood VR-616 Receiver
How do you program a mute button for the speaker phone? It doen't have an actual mute button. Been doing some online phone meetings and the instuctor keep saying mute the phone.
It depends on what the phone is plugged into. The SP-308 and 616-ex don't have programmable buttons. The 616-Flex and higher, up to the 96ex do. In a Flex, it's based on *40 under a flex button.
Aug 08, 2011 | Vodavi Enhanced Starplus SP-61612 Corded...
Receiver makes clicking sound before power shuts off. i checked all speaker connections for shorts per troubleshooting!
What you are hearing is the speaker protection relays. See the link below for a generic explanation of protect mode (the mode your unit is in at the moment.) Update this if you have some test gear and wish to attempt to repair this.
Sep 27, 2010 | Kenwood VR-616 Receiver
Paging feed back
Or move the speakers that are next to the phones doing the paging.
It feeds back because the speakers are loud, and are blowing the sound into the mouthpeice of the phone that is paging.....
May 26, 2009 | Avaya Lucent Partner 616 Phone
Static in my phone
Do you have broadband, it sounds like you need to install a broadband filter.
Jan 10, 2009 | Avaya Lucent Partner 616 Phone
Can't charge my l6 on my pc
you cannot charge your mobile on ur pc directly via a uab cable.For that you need a motorola phone tools software which connects your phone as a modem and you can transfer pictures, sounds, videos to your mobile and your mobile will also be charging at the same time.
Dec 24, 2008 | Motorola Mobility L6 Cellular Phone
Amp not working need repair
You should open the amp and check if you've popped a transistor. It could also be that you've blown a relay... which really sucks lol
Dec 11, 2007 | MTX Thunder 81000D Car Audio Amplifier
Mobile soft.
What do you mean by uab.. if it is usb driver that you want...LG B2050 doesn't have an USB port! Phone spec. here..
Sep 14, 2007 | Computers & Internet
77 people viewed this question
