Question about Samsung Televison & Video
Samsung TV model un46es6150f does not turn on but stand by light is on
    Top Expert:
  • Samsung Master
  • 34,124 Answers
Open internal fuse or power supply failure.
Posted on Dec 05, 2016
Testimonial: "What fuse?"
    Master:
  • Samsung Master
  • 708 Answers
I have a samsong model UN46ES6150F tv with no backlight... sound is ok........... I have replaced the Power Supply/LED board..........No help, same problem...
Fault at its main digital board. Back light control voltage from it is absent. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 13, 2017 | Televison & Video
How do I fix my Samsung LCD TV?
It rather seems to depend on the model. I have seen Two videos on YouTube, one says it could be the LED back lighter, with a burned or shorted out LED(s). In the other it says it is the power supply board. But both were different Samsung TV's. The LED one if that looks tricky to do. If it is the power board, which I think it could be, you should be able to get the full board fairly cheap. Just be careful with the voltages when removing it, if you intend to do it yourself.
To see the Videos just type "Samsung TV blinking lights" into YouTube.
May 19, 2016 | Samsung Televison & Video
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
I have a SAMSUNG model HL-T5076S flat screen TV. A blue light stays on at the bottom of the set after I turn the TV off
Acording to the user manual there is an indicator light that Blinks and turns off when the power is on and lights up
in stand-by mode.
This information can be found on Pages 6 & 7 of the Owner's Instructions wich can be found here:
Sep 16, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung rear projection tv
WE always need the model #..............................T.
Nov 15, 2007 | Pioneer PRO-99 TV
Open Questions:
Televison & Video Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
