Sir I have a HITACHI WASHING MACHINE PROBALAM FD WASHING MACHINE IS TOP LOAD TELL ME SALOSHAN
  • 1294 Answers
SOURCE: washing machine
Possible your outlet filter is blocked, find it and clean out. Look into yr users' manual
Posted on Sep 15, 2007
  • 38 Answers
SOURCE: LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Posted on Jul 23, 2008
SOURCE: hitachi top loader washing machine
Could be the safety switch which is faulty which is activated by closing the lid. There is a plastic section on the left hand side of the lid which activates the switch. The plastic lip on my model broke so i riveted a piece of alumimium in place
Posted on Apr 18, 2009
  • 326 Answers
SOURCE: My Kenmore washing machine, top load, will not
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 06, 2009
SOURCE: adjutator for 500 series washing machine
fault code 40
Posted on Jan 21, 2010
My Hitachi washing machine topload model sf-120 kj showing error code FD
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 02, 2015 | Washing Machines
I got C4 error on Hitachi FX80GJ washing machine and it stopped spinning. How can I fix it ?
Hitachi washing machine top loading is Sher coming C4 is dry too much sound coming
May 16, 2015 | Washing Machines
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
I need an operating manual for a Hitachi SF-65PX Top load Washing Machine
Hitachi recommends that you contact them for copies of their product guides that arent avaiable on their website for download (which it seems your washing machine is one)
see below
http://www.hitachi.ae/products/consumer/customersupport/productmanuals.html
May 16, 2010 | Sprint Hitachi P300 Cellular Phone
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
