Question about Cooktops
We have a Princess model 2276 LP gas cooktop and one burner has a higher flow rate than the other. Is there a way to adjust just one?
fridgetech
  • 473 Answers
SOURCE: Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Posted on Oct 17, 2007
  • 1314 Answers
SOURCE: low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Posted on Dec 30, 2007
  • 150 Answers
SOURCE: KitchenAid 5 burner Cooktop conversion to LP gas
you need orifices for lp and the regulator should be convertable there is a "plug" thing in the middle of it that you remove and turn over and install
Posted on Apr 23, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
appldoctom
  • 311 Answers
SOURCE: Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Posted on Feb 13, 2009
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Control knob doesnt adjust flame height?
    Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
    Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
    Bluestar rangetop clicks several times before igniting
    Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
    Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
    NEED KNOB PART #80421
    http://www.suremarineservice.com/80421.aspx
    Mar 05, 2013 | Seaward Princess Model 2276, 2 burner...
    Soot deposits from my brand new downdraft jenn-air gas cooktop
    Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
    Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
    Simmer is too hot
    one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
    Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
    Converted a ge gas to lp. the oven and broiler has too much flame
    You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
    Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
    Apr 15, 2008 | Cooktops
    Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
    Cooktops Logo
    97 people viewed this question
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
