Question about Electrical Supplies
Where do the black, white and red wire go?
Have a motion detector hooked up to my garage light. I want to remove it and have the lights come on with a dusk to dawn screw in sensor. The lights are connected to an on and off switch. The motion sensor has a small flat wire plugged into one end of a rectangular black box about 1x 2. On the other end it has a white a black and a red wire connected. If I remove these where do I connect them to have the lights automatically come on at dusk and go off at dawn?
SOURCE: Photoelectric Control (Photo Eye), dawn to dusk, install
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
Posted on Dec 05, 2008
cj2176
  • 520 Answers
SOURCE: Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Posted on Jun 15, 2009
SOURCE: my motion sensor stopped working--the lights are full on all day.
i have pir movement the problem is without movement its getting on
Posted on Sep 02, 2009
  • 14311 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
Own a Heath zenith sh 5105 motion detector flood light. I wired it to plug into an outlet. Flood light comes on when I plug it in and stays on. Seems as if the sensor isn't working. Do I have it wired...
look to see how you have it wired, most sensor lights have many wires to put together, if it is not wired already from factory, you need to look to see how you have it wired, most sensors have three wires one black one red and one white, black wire goes to power, red wire goes to lamp, white goes to neutral, after all is wired you should have only 3 wires a black a white and a green, black to power white to home neutral and green to ground
Oct 31, 2011 | Home
Hi my question is motion spot light has has two black wires one from each light and two white from each light and one red from the motion detecter which is connected to the black wires there are two wires...
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Dec 18, 2010 | Home
I am trying wire a motion Senior its has 3 wires coming out the back red white black
To connect a separate motion detector to a light fixture (and assuming the fixture uses incandescent or the newer twisted florescent light bulbs), the RED wire from the detector is attached to the black ("hot") wire from the fixture; the WHITE wire from the detector is attached to the white wire from the power source; the BLACK wire from the detector is attached to the black ("hot") wire from the power source. Sometimes the white and black wires from the power source are mixed up, reversed. So it is best to check to determine which wire is actually "hot" (shows voltage in a meter between the wire and the ground wire or the metal box the power wires come from). In general, a colored wire (often black) in the power source, if wired properly according to accepted custom, will be "hot" and 120v in US. The white wire in the power source is called the "neutral" and should be neutral with the ground wire and/or the metal box. If there is another colored wire in the power source (often red) and if it is not taped with some black tape (to indicate it is really a black wire), then it too may be a 120v. hot wire, but it may also be an 120v. hot wire that is 120v opposite the other 120v wire. That is, one 120v wire is 120v+ and the other is 120v- The difference in voltage between these 120v wires + and - is, hence, 220v. If you see multiple colored wires, it is also a good idea to check the voltage between them to know if you are dealing with a power source that entails 220v. In short, you want to know what you are doing, obviously for personal safety, but also to accomplish what you want... to properly connect the motion detector.
Dec 12, 2010 | Home Security
I have a motion detector console which does turn the lights on the garage door opener when it senses motion, but it fails to turn it off from time to time once I've left the garage. I've replaced the...
The wires going to the wall control are color coded. One of them is white and the other is white with a red stripe. Make sure they are attached to the correct terminals at the motor unit and on the back of the wall control.
Oct 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do myou connect a 110 motion light
The motion light comes from the store with a neutral (white) hot (black) wires. If there are multiple light bulb sockets on the motion light, the black wires will be connected together and the white wires will be connected together. There will be a motion sensor that has a red, white and black wire. The red wire is connected to the black wires from the bulb sockets. The remaining white and black wire from the sensor switch are connected to the line power from the panel. you must remember that all white wires from the entire project are to be connected together.
Most motion lights feed the line power from an independent switch that connects the power to the motion light fixture. Remember never to connect the white conductors to any red or black wires, as this will create a ground and you will continue to trip your circuit.
I hope this has been helpful.
Aug 15, 2010 | Home
Lights only work in test mode sensor picks up motion
You are talking about a motion detector attached to some type of light I presume. Your numbers mean nothing, I'm sorry to day.
Very first consideration, you do have it correctly wired, right? White to white - black to black - green to green and ground. The red goes to the lamp black wire, right??? (Light White goes to neutral (white line))
I am very familiar with motion detecting lights, working at a large resort at the seashore.
Two conditions that must exist for this light to come on ... it must be dark and there must be a motion. There should be two adjustments on your detector; one is for sensitivity and the other is time the device should remain on.
Dark ... not just sundown ... are there other lights in the area that may cause your detector to think it is day time?
Sensitivity. On minimum sensitivity, your detector is nearly blind to any but the closest movements. On maximum, it will probably see bats flying by. You must adjust to meet your needs.
Does it have a warranty? I dont know. You would have to check the information that came with your light.
I hope this information helps you ... Positive comments are appreciated.
Thanks for clarifying your question and thanks for visiting FixYa.com
a
Oct 27, 2009 | Electronics - Others
Dsc sensor not operating properly. I want to change it, is this very difficult? Thank you.
You don't mention what type of sensor. I assume it is a motion detector. Before replacing I would strongly suggest you first remove all power from the system by disconnecting the backup battery inside the control panel then pull the system's power transformer which should be plugged into an electrical outlet nearby. You will know that all power is removed by looking at the keypad - all lights on the display are off. Next remove the motion detector's front cover. Some detectors have a small screw on the bottom so that when removed the cover pops off. Others need to be opened using a flat blade screwdriver and prying off the cover. Once the cover is removed there should be a 4 conductor wire that is wired to a series of terminals. Observe the polarity of the wires, disconnect them and remove wall mounting screws. Install new unit. Be sure when wiring to connect power wires correctly. The 4 conductor wire should have a red (positive) wire and a black (negative) one. Connect the red to the + or pos terminal and the black to the - or neg terminal. Read the instructions that came with the new unit if in doubt. When finished plug the power transfomer back in then reconnect the battery (in this order). If power is connected properly the motion detector's red walk test light (indicating motion) should light whenever you walk in the protected area. Also make sure the system recognizes motion by first closing all protected areas such as windows and doors to get a system ready or green light indication on your keyad, then walk around the protected area. A properly working detector will show you a fault on the keypad everytime the system senses motion.
Sep 11, 2009 | DSC Home Security
Electrical Supplies Logo
100 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
