Question about Proview Televison & Video
How do I adjust the resolution on a Proview Television, model 3200?
5 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: proview tv... 1080p????
if it has either hdmi out,,or comonent out,,then yes,,probly 1080p,,or at least 720p,,thats good
Posted on May 17, 2009
SOURCE: proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
praky16
  • 744 Answers
SOURCE: Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 07, 2009
SD Tech
  • 14553 Answers
SOURCE: no picture or sound on my tv proview model 3200
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_30_2012_4_55_45_pm.jpg
Posted on Apr 30, 2012
How to get another tv remote?
Find a seller of the product and ask them
Oct 18, 2014 | Proview Televison & Video
How do I get a new remote for tv model 3200
Find a Proview dealer and ask them for one
Cant find the on manual botton
front panel of TV...........center (ch... up/down.......vol up/down power)
Apr 17, 2011 | Proview PA-32JK1A 32 in. LCD Television
Blacklignt turns off after 15 min
undo the back and check the inverter board.
Fosg2000, please rate me
Mar 17, 2010 | Proview PA-32JK1A 32 in. LCD Television
thank u!!!
rate me
Jul 07, 2009 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview 3200
Pat I do not know if you have a warranty you were required to retain the receipt from the store for the length of the warranty period to prove you have one ,also it is a good idea to register with the company on their website so they have a record of your tv and model, with your name and therefore the warranty they have included if any.LCD tv's are one of the most unsupported mass marketing consumer items that are being dumped on the US market. I think you have Blown capacitors, or more likely a problem with the power board, typically this requires soldering new capacitors onto the power board after unsoldering the blow ones and if this is all the problem is the issue will disappear, if there is an issue with a transformer, or some diode or computer chip then you might as well replace the whole power board. the capacitor issue is no big deal if you can get an electronics service center to look at the problem.
May 22, 2008 | Proview PA-32JK1A 32 in. LCD Television
Televison & Video Logo
51 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
