Question about Coffee Makers & Espresso Machines
Steam not coming out strong enough to froth my milk.
Hi, I have a Syntia sup 037r, and the steam wand is not providing enough strength to froth my milk. I descaled the machine yesterday, and it worked fine for about two cups of coffee. I have flow, but the steam starts very strong, then peters out. Should I descale again?
SOURCE: Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Posted on Sep 17, 2007
j_del
  • 1586 Answers
SOURCE: Gaggia Classic Espresso machine
Sounds to me like there's a leaking gasket or joint somewhere in the frothing system. Your first bet is to check around the parts you replaced - did a gasket get squeezed or seated incorrectly? If so, it'll cause a pressure leak that will keep the frothing minimized. You'll still get the mixes (as you said) but they won't be frothed as they should because the pressure is leaking out along the way. Another idea would be to inspect the nozzle itself for a crack or damage - if that's the case, it'd cause the failure just the same as a leaking gasket could. Check around the parts you've replaced or adjusted first, since you know there was work performed, and that means there's always the chance that something was inadvertently missed, damaged, or (in the case of a gasket) not seated quite right.
Posted on Aug 27, 2008
  • 2976 Answers
SOURCE: steam does not come out of steam pipe
If you wait too long after making the coffee, you will not have enough water left to make steam. Try to steam the milk immediatels after the coffee loses pressure.
Posted on Jan 16, 2009
  • 906 Answers
SOURCE: kitchenaid artisan coffee machine - steam wand
good day,
hope this link below will solve your problem..
kitchen
Posted on Aug 04, 2010
espressonist
  • 1711 Answers
SOURCE: There used to be enough
This a
clear problem from scale builds up in the boiler. The scale layer is acting as
an insulation layer which is reducing the efficiency of the heating element to
the boiler and also reducing the water capacity thus also the steam production
capacity.
So you
should first try to de-scale your machine three four times with intervals of
three days from each de-scale. Try also to perform the de-scale very slowly
like when you will flash the water solution from the water reservoir take about
30 minutes why drawing a coffee cup every five minutes. With this way you have
very good chance to remove a lot of scale and you machine heating efficiency to
be increased. If after the above procedure you have no difference then you need
a new boiler which is one unit with elements and sensor.
Here below we
have a link with more information for your machine which can help you.
http://www.partsguru.com/SaecoMagicDeluxeSuperautomatica.html
Posted on Dec 23, 2010
THE FROTHER SPOUT KEEPS BLOWING OFF DURING THE FROTHING
I'm guessing this is a table top machine. If so then I take your meaning of "Blowing Off" as in turning off or running out of steam. The table top steamers usually found on home units do not have the capacity to froth large mugs like a "Venti" 20 oz cups. You will have to wait for the boiler to re-heat. It's best to heat a smaller cup of cold milk, pour the milk into the venti and make a 2nd batch again with cold milk. (It's hard to re-froth hot milk).
* check your steam wand tip if it's plugged with old milk. Soaking the wand in warm water overnite will help soften the milk which can be blow out when you make steam again. If you make a lot of milk drinks, it's a good idea to give the wand a blast of steam, then a good wipe with a damp cloth to keep milk residue off the wand.
* It's also possible your steam heater is starting to clog up. If you find that it gets slower and less steam with time then the steamer will need to be replaced. Check your warranty and call for service.
* Please update question with brand and model if you want more help.
Aloha, ukeboy57
Jan 29, 2018 | Coffee Makers & Espresso Machines
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
How do i use the steam wand to froth milk
The steam wand to froth milk, you need a certain amount of milk in the cup first, then if you tilt the cup a little towards you, push the steam button and "it should froth your milk right up", but if that doesn't work then I don't know.
Mar 24, 2014 | Bella Espresso Maker - Black
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Steamed milk is not coming out
Clean the steam wand, it unscrews and needs to be cleaned, also, descale the machine once the blocked tube is cleaned. When milk dries it is like glue and clogs the steam wand. so clean it daily after use.
Also, I think you meant to say, steam for milk frothing is not coming out. If you meant steamed milk is not coming out, it's not supposed to do that. Some Saeco's can add an attachment called a milk island but not the magic comfort plus.
Mar 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Nov 20, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
