Husqvarna 45 chain oiler is not working...all the oil ways appear to be clear...the oil pump is rotating when I pull the starter cord...is there a pick-up lead in the oil tank that may be clogged?
Previously used engine oil was used to lubricate the chain.
Depending on the model, yes. But first I would remove the bar and chain and make sure the 4 or 5 square openings behind the bar for the auto oiler are not clogged with gunk. If everything is clear and the oiler adjustment is turned up as high as possible (15ml/min), you may have a problem with the internal pump.
Also, a chain will smoke if the tension is incorrect. Before you use it again, when cold check the chain tension. You should be able to see about half of the chain drive when pulling on the chain. Another thing may be the sprocket tip if applicable. Make sure it is properly greased each time you add fuel/bar oil.
Did you get it Lowes? Most new homeowner class chainsaws have no oiler adjustment (bad idea! lots of problems). If it does there is a mention in the OM under or near bar maintenance.
Intermediate class saws often have a 3 position oiler. The professional grades have fully adjustable oilers. HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarificationhttp://www.husqvarna.com/us/homeowner/support/customer-support/) 15 = week produced – March 00198 = 198th unit Husky produced that week
Oil System Plugged:
Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa.
Second duplicate post: You provide no model or serial numbers, start with the IPL for your saw. It can be found here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week Oil System Plugged.
Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification. Most Huskys have an outboard clutch we will presume this one does too. Use this a guide for clutch removal: R² Drive Link Outboard Clutch by Drivelink.blogspot.com http://www.youtube.com/watch?v=cdqkIuVNUQc
Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
The clutch is under the clutch cover, Watch the video. I hope this is most helpful. If you need additional help you can reply below and I will gladly assist you further. Good Luck, it is not as difficult as it appears. Lou Second duplicate answer:
Your saw (Husky 235E) is not fitted with an adjustable oiler. The manual does not mention using a thinner oil with lower temperatures. If it was run for an extended period without oil it may have caused a little wear to oiler components. I would take it into a warm area, let it acclimatise, and test the oiler as follows (it will probably oil the surface it is sitting on; my Lady would not be happy if I oiled her table!): Oil System Plugged.
Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
Manuals here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week
It is equipped with an outboard clutch, the oiler is below it. This will help you remove clutch parts. R² Drive Link Outboard Clutch by Drivelink.blogspot.com http://www.youtube.com/watch?v=cdqkIuVNUQc
A phone call to your local Husky dealer for an estimate might provide a pleasant surprise. I might inquire just to get recommendations for using the nonadjustable oiler. It is not as difficult as it appears. Good luck. HTH Lou
I read the the Technical Data for a 2008 - 450 page 39 and your oiler is not adjustable. You can down load an Operator's Manual and IPL here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week
It has an outbaord clutch, illustrated on the IPL, detail B. The oil pump and worm gear are behind the clutch. This will help with clutch removal: R² Drive Link Outboard Clutch by Drivelink.blogspot.com http://www.youtube.com/watch?v=cdqkIuVNUQc
It is not as difficult as it appears. Good Luck Lou
Caution it is probably only a 3 position oiler, forcing it beyond either stop may cause failure. The 2009 om (may not be your saw) adjustment is on page 33 of the Operator's Manual (below). Oil System Plugged.
HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week HTH Lou
Everyone I have ever removed had a left handed thread (tighten it to loosen it). Let us know how it worked for you.
An IPL for your saw can be found here (the IPL I found was 4 pages in, if not yours please keep going): HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week HTH Lou
An IPL with oiler components and part numbers can be here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – for use with IPL 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week Our job is to provide the knowledge and illustrations available to help you determine which oiler component has likely failed. Your job is to apply that knowledge and make the final determination. If you aren’t comfortable doing that then your only option short of saw disposal is your friendly local chainsaw seller/mechanic. You might be pleasantly surprised at how reasonable they are. Oil System Plugged.
Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no, continue with 2.Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Is this a new saw? If yes please contact Husqvarna about a warranty (2 years) repair. I think you already performed part 1 below.
I've 7 chainsaws. 6 of them oil my bench if I forget to drain the oil tank.
You don't give us a model number not all saws have oiler adjustments. An IPL of your saw with oiler detail can be found here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – for use with IPL 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week
Oil System Plugged.
Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
