Question about Sharp Televison & Video
I have 120 plugged in to a Sharp television set I have no black place for the black Outlet.
2 Suggested Answers
bmwrider
  • 215 Answers
SOURCE: Power Source
Are you certain the polarity of the connections to the TV are correct? If you connected them in reverse you may have damaged the TV. If there's a fuse in line check that too. BMW
Posted on Jun 01, 2006
Sharp television not powering on
Try unplugging the set for at least 10 minutes. Also be sure the outlet that the TV is plugged into is working. You can test this by plugging something like a lamp into it.
If the TV still will not turn on, you have a problem with the power supply inside the TV - it will have to be repaired.
Oct 03, 2016 | Sharp Televison & Video
Logo comes on, fades to black
Check that the input on the remote is set to where you television signals comes from.
Oct 07, 2015 | Sharp AQUOS LC-90LE657U 90" LED TV...
I have a 12 inch chraftsman table saw with 2 wires coming from motor. The wiring diagram inside the cap shows it to be wired for 240 how do I wire that thru a switch and to a three wire recepticle
Not quite sure what your question is - Are you trying to plug a 240 into a 110/120 outlet? Or are you trying to plug this into a 240 3 prong outlet?
Traditionally, table saws don't come with a power cord - you must supply one. Usually on the motor there is a metal plate that describes volts/amps/phase/hp etc. Get the Volts/Amps from this plate, then measure the approximate distance between your table saw and the 240 outlet. The gauge of the power cord depends upon the Volt/Amps and the length of the cord. There are many volts/amps vs length for wire gauge conversions on the net. I always get a bigger wire (smaller gauge) than what is recommended. Expect to pay $100 or more for the cord (don't be cheap here). If you have an under rated cord, you can start a fire, burn up your motor, melt plugs into outlets and have to replace the outlet (don't ask how I know).
I'm a little suspicious of the "white and black" wire from 240 - it's usually "white and red" with a "black" ground. 240 is made from two 120's - opposite sine wave. So black is usually the common ground, while the white and red are the two 120's. Volts between white-red=240, white-black=120, red-black=120. If you're absolutely sure that white-black=240, then you can just connect a ground wire to the motor case. Many home table saws can be wired for 240 or 120 - you need to make sure that you're hooking 240v to the correct wires. If you're uncertain at all, then don't do it.
I have wired 120 to a 240 motor by accident and the motor ran - it had no power and didn't spin at full RPM. You can damage a motor this way, so I wouldn't recommend it. I have never put 240 to a 120 motor - so I don't know what happens (guessing you could burn up the motor coils).
With all that being said, if you have 240 outlet with 3 wire receptacle, then just use a multi-meter to determine the 2 "hot" and the 1 ground. Volts from hot1-hot2=240, hot1-ground=120, hot2-ground=120. If you don't have a multi-meter, buy one (approx $12). Once you have it wired up, then try the motor by flipping the switch on then off again. If the motor didn't spin, then you did something wrong. If it hummed but didn't spin, you have some connections wrong inside of the motor. If it spins the wrong way, then your wiring inside of the motor is wrong (doesn't help to flip the wires on the outlet). If you blew a circuit breaker, then the wiring to the motor is wrong.
Sep 27, 2014 | Saws
Wire hook-up
see schematic on side of inside back cover if 120 volt plug that goes to outlet then if 12 volts from black and green ground go to block they should be marked
Jun 18, 2013 | Dometic RM2620 2 WAY REFER
I live in germany (military) what is the power 120-240?
Good day!! The 120-240 power simply means the supply of your TV can be plug in to 120 Volts AC to 240 Volts AC that will come out to your outlet.For example your outlet is 120 Volts AC you can plug in your TV in there.In short your TV supply is auto-volt.
I hope this information could help you.Thank you.
Apr 17, 2011 | Proscan 24LED45QA TV
T V Cycles off and on as long as plugged into power outlet.
Your problem is the AC outlet, you must have an electrical problem. Call an electrician and ask him or her to run a voltage check or if you are able to, get yourself a multimeter turn the dial to AC voltage and place the red and black prongs into the outlet and see if you are getting a steady flow of voltage it should range anywhere from 110-115/120 volts AC.
Jun 28, 2010 | Televison & Video
Sharp TV LC37D40U Aquos malfunction. It fails to turn on (no picture, no sound) except that power button light blinks off and on continuously. Any ideas. Thanks.
The blinking light is a indicator of a internal failure, it usually blinks as an error code, I have two suggestions, unplug the TV from the power outlet and let it set for at least 30 minutes not plugged into the wall outlet, then plug it back in and see if it has returned to factory defaults and returned to normal operation, if that didn't work then contact sharp @ 1-800-237-4277 and they will gladly assist you. Good luck !
Nov 30, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Power Source
Jun 01, 2006 | Ktv 9BNC 9 in. Television
Televison & Video Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
