Question about Casio Cdp-100 88 Note Digital Piano
CDP100 CASIO PIANO VOLUME CONTROL SCRATCHY. UNABLE TO ACCESS THE POTENTIOMETER. PL HELP
  • Casio Master
  • 9,639 Answers
Try this first with the piano off, run the control from stop to stop rapidly several times. The object is to clean off any dust deposits and shine the contacts inside the pot. If the pot is not damaged beyond repair, then this should fix it.
Posted on Dec 06, 2016
Hugh fulton
  • 62 Answers
SOURCE: casio ct 636 e-piano LOW volume on all keys and instruments
Sounds like the built in amplifier is going down. You could put it in to a music shop and have it repaired or buy a small 10 watt amplifier and plug in from you headphone socket to the amplifier. I suppose it depends what is the cheapest way to go and how much you are prepared to spend as the keyboards are pretty cheap nowadays especially on Internet shops.
Good Luck
Posted on Sep 13, 2009
  • 222 Answers
SOURCE: Scratchy volume potentiometer
Try cleaning your volume potentiomenter with contact cleaner (they come in spray can's), the scratchy sound is audible when you turn your volume control on, the contacts inside your potentiometer accumulated dust or some other particles.
Posted on Aug 12, 2010
  • 5603 Answers
SOURCE: what potentiometer is being used in rbx 374 bass
Yes, active use different value pots than passive. The volume control is LIKELY an "audio taper" which can be either an "A" or a "B" marking as there is confusion about the marking. The resistance is likely around 500K ohms down to as low as 50K ohms. The marking MIGHT be something like 504 B or 503 B or the same with the letter "A".
An A500 pot might be only 50 ohms... That would result in very low output. Again, the marking in the industry is not consistent.
Best bet is to get the part from Yamaha. Go to Yamaha America "parts" dept in California. You can search the phone number with Google.
Posted on Oct 11, 2010
  • 41 Answers
SOURCE: I have a Casio Privia
Beofore you replace it, if it is only scratchy give it a good working by sliding it back and forth a rew dozen times. (if it is a slider type) If you can get some electrical contact cleaner with a thin plastic tube, try squirting that into it and work it again, if that fails, then look at the volume control replacement.
Posted on May 06, 2011
  • 12962 Answers
SOURCE: Fix for a missing volume control
For what piece of gear?!?!?!?!?!?!?
Posted on Dec 11, 2015
How do i adjust the drum rhythm volume so it is louder than the tone settings
You ay have to edit a rhythm and save it as a "user defined rhythm". During editing the volume of each part can be defined with vol. level ranging from 0-127.
Please read the manual.
Metronome volume can be easily changed by just holding the metronome button.
Mar 22, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Tip
Electronics spray cleaner
The most common problem with guitar amplifiers
and other electronics that are making noise or cutting out
or sticking and not working correctly is a simple fix...
I use Radio Shack electronics spray contact cleaner
for most of my basic repairs
in the pictures posted I show the basics you need....
some screw drivers, basic knowledge, paper towels,
electronics spray contact cleaner, and a knife
First I carefully remove the nobs (volume control, tone control, etc...)
I use napkins to mask the area and keep from scratching the surface
Then I carefully spray into the (control} and work in back and forth....
the Best way is to spray directly into the potentiometer
that requires access to the internal chassis
on a quality pot there is a Notch that you want to spray into
on a standard pot just spray....
this will repair any scratchy noise or sound that cuts out
on guitar and bass amplifiers,
also can be applied to many other common basic sound problems
I hope this helps someone out?
i could Not upload photos? so please check My link....
https://plus.google.com/105897664234915107933/posts/iHG1R6dpvkU
on Mar 13, 2015 | Music
Hi i have a casio piano px-120 and the volume is not working, like it is stuck in certain volume level and even when i move the volume up it stays the same. ive been wanting to fix it because the volume is...
2 possibilities: Dirty control/cursor...clean with electronic contact cleaner. NOT WD-40 IT IS A CORROSIVE CLEANER.
Or bad control or connection to control. Get access to the "underside" of the control and check. Hope this helps.
Dec 07, 2013 | Music
Turns on but there is no volume
If the volume control is analog (meaning it is an old rotary and not digital) - it may just require cleaning.
Pick up a can of electronic switch cleaner.
Nov 13, 2013 | Casio Ctk691 Keyboard
The volume conrtol knob on my Casio Privia Px-320 doesn't work. The volume won't go up or down and the knob feels loose. Can I fix it at home?
I found an answer at the end of this page: http://music-electronics-forum.com/t31080/ After replacing the potentiometer volume is OK. The original potentiometer has a very delicate axis.
Dec 29, 2012 | Music
I have a Casio Privia PX-110 electric piano. The volume control is not working properly. How can I get to it to replace it?
May 05, 2011 | Casio 88 Key Digital Piano With Stand...
I own a Casio CPS-80s Digital Piano. It stopped playing due to something related to it's volume / amplification has stopped working. I can barely here the sound of the music, so i maintain hopes of...
You will need to contact the Casio parts department and they can provide you with an electronic schematic for your CPS-80 digital piano. This document is not available to view on the Casio website Casio Parts Department
1-800-223-2001
http://support.casio.com/manuallist.php?rgn=1&cid=008
Dec 23, 2010 | Music
The Master Volume control on my Line 6 Flextone II Head is scratchy-noisy when I turn up the volume. I am looking for a replacement, but, Line 6 does not have it on their replacement parts site. The phone...
First try spraying a bit of CRC226 (aaaaaa9make sure it is 226 as there are other products with similar numbers there)available at Home Depot in the electrical dept. into the control where the leads go into it. You may need to bend the plastic spout of the spray can at 90 degrees near the end to get it to go up into the control. This has a high probability to solve your problem.
Getting replacement controls that exactly fit are a major headache from anyplace than the original manufacturer.
Aug 27, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Aug 11, 2010 | Alesis Sr 16 Stereo Drum Machine
Casio Cdp-100 88 Note Digital Piano Logo
52 people viewed this question
Top Casio Music Experts
Ben Armstrong
Matthew Spark
Matthew Spark
Are you a Casio Music Expert? Answer questions, earn points and help others
