Question about Car Audio & Video
Older 3-piece AmerTouri set. The middle suitcase is in CA. Want to ship it back to GA, but need dimensions. It is 24 or 25 inches. Wants to purchase custom box to ship it. Please help with dimensions?
5 Suggested Answers
  • 1586 Answers
SOURCE: dimension please for enclosure 12w3v2-d2
Typically you use one cubic foot per sub, so a 2 cubic foot box will work fine. To build a basic one, just a rectangular box, using 3/4" MDF (excellent material for a box), cut pieces this way:
2 - 25.5" x 13.5"
2 - 25.5" x 12"
2 - 12" x 12"
This will give you an interior volume of exactly 2 cubic feet. Cut your sub holes out of one of the 25.5" x 13.5" pieces.
Posted on Sep 24, 2008
  • 74 Answers
SOURCE: box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Posted on Feb 17, 2009
  • 655 Answers
SOURCE: I am building a custom box for 2 15 inch Kicker
Hello bgl6176,
According to their specs, the L7's will work in a ported enclosure with as little as 3 CuFt and up to 6 CuFt. Usually with ported, bigger is better, so let's use the 5 CuFt per chamber. I'm assuming that you have room for a 10 CuFt box in the trunk? That's a big box? Almost half as big as a medium sized refrigerator. I hope you don't plan on putting your golf bags in there too. For 10.15 CuFt, a box will need to be 36X29X20, allowing 0.15 for the partition, sub, and port displacement.
To tune each chamber to 30Hz, you need a 4" diameter port 4.6" in length. Lots of custom builders use PVC and even ABS pipe for round ports. You can also buy "pretuned" ports from sites like
You'll have to measure the exact room that you have available and then adjust the dimensions accordingly.
Here's a link to a great site for calculating almost anything in box building and subwoofer related. You can use the old "multiply LxWxD and divide by 1728" and the other formulas too, but here you can plug the figures in and immediately see the results.
Hope this helps.
Posted on Oct 19, 2009
Testimonial: "Thank you so much for your help!"
SOURCE: need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
I have the same sub on the "digital" amp from the same company.
I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
Posted on Jun 12, 2012
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
Sep 16, 2017 - Uploaded by Distant Lands Travel Store How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA LockĀ® & Cable - YouTube
? 1:21
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ... > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Lock Instructions - Samsonite Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
What is the weight limit on Spirit Airlines for a check in suitcase?
hi deborah.
Checked bags: Maximum of 62 linear inches (length + width + height; 158 cm) including handles and wheels and maximum of 40 pounds in weight (18.1 kg). Any bag that exceeds these dimensions or weight limit is considered oversized/overweight and has a corresponding charge.
What are the size and weight limits for bags? - Spirit Airlines Support
What is the weight limit on Spirit Airlines for check in suitcase Google...
Nov 07, 2017 | The Computers & Internet
Size of suitcase dimensions of luggage
Carry On Size Chart 150 Airlines Travel Made Simple
How to Pack for Air Travel
Check the individual airlines sites you are traveling with to confirm allowances for baggage size and weight and number.
Jun 19, 2017 | Luggage & Travel
I need the Linear feet: It measures 24" tall, x 10" thick, x 15 1/2" wide. Can you help?
linear feet is a length measurement as to how long it is --example : a piece of timber 20 feet long is 20 linear feet
the measurements you have provided will give a cubic feet measurements which is a volume measurement. so convert all the dimensions to feet , multiply all together and that will be your volume
May 03, 2016 | Luggage & Travel
The directions call for an inch and 3/8 daim hole for installation but when i go to install the drain its to big?????
DUH that means a 1 inch hole for the middle and a 3/8 for the side holes not 1 3/8 to begin with
Feb 24, 2015 | Jado Plumbing
How-to I replace facing on older whirlpool dishwasher
  • 1. Place your hands at each end of the retainer trim piece that runs along the bottom of the dishwasher door panel. The piece may be metal, black plastic or another color, depending on your dishwasher model. Lift up on the retainer section and pull it toward you to remove it. Set the retainer aside.
  • 2. Press the palms of both hands on the old facing and slide it down until the top is free. The facing flexes easily to allow you to slip it out from under the trim along each side.
  • 3. Hold the replacement door panel, or reverse the old one, so that the desired color is facing you. Turn the panel, if needed, so the dimensions line up with the dishwasher door.
  • 4. Slip the side of the facing into the left side of the frame on the dishwasher door.
  • 5. Secure the other side of the facing into the right side of the dishwasher frame by bowing the panel gently and sliding it into the frame.
  • 6. Slide the new facing up and into place so you can reposition the retainer.
  • 7.Hold the new color panel and the spacer behind it up over the lower edge of the frame about 1/4 inch.
    8. Snap the retainer into place. Push down on the horizontal piece gently to ensure it is securely connected.
  • 9. Adjust the new panel down a bit with the palms of your hands to cover the 1/4-inch space.
Oct 19, 2014 | Whirlpool Dishwashers
Will 3" sanitary pipe be sufficient for the kohler k3427 toilet?
Yes it should be fine, go to Kohlers website and check the rough-in dimensions to see what size the waste hole is on the toilet usually 2 3/8 to 21/2. If it says 3 inch you might just need an adapter ring.
Sep 20, 2014 | Kohler - Toilet - Two-piece - Highline -...
Frigidaire washer won't agitate or spin -
If it is a front loader go behind the washer and look for 4 or 5 bolts. They are shipping bolts they need to be removed generally they are 2 on left and right and 1 in the top middle. If it is a top loader tip the unit back and see if there is a piece in the middle that is stopping the drum. Generally styrofoam or cardboard. Either way I would video tape this process as you may need it if your have problems with the washer later to get a new unit or service to fix it. If it is an older unit your belt of drive system has probably gone out and it is in better interest to buy a new unit
Sep 03, 2014 | Washing Machines
Do u know the dimensions of the rear projection/it quit working
These are the dimensions of the TV itself (including the bottom piece)
The height of the TV is 37.2 inches tall
the width is 49.6 inches wide
the depth is 17.4 inches deep.
the weight of the TV is 132.5 pounds (just thought you would want the weight as well if you are considering purchasing a stand)
I hope this helps and good luck!
Feb 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
