Question about Lakewood Heating & Cooling
Knob for lakewood 792 elect. heater. control shaft is 1/4" in diameter with flat bar on top.
SOURCE: Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Posted on Apr 22, 2007
  • 77 Answers
SOURCE: Lakewood heater 792/AA
sounds like a broken element or wire. with unit unplugged, using an ohm meter check all connections and check elements for resistance.
Posted on Jan 22, 2010
SOURCE: lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Posted on Oct 01, 2010
SOURCE: lakewood heater model 6500 the top high low knob
you can still use this heater, but continue to monitor its operation. If it gets hot enough to start smoking again, discontinue use and purchase a new one. Your safety means EVERYTHING!!!!!!
Posted on Nov 27, 2010
  • 224 Answers
SOURCE: Lakewood Model 792/A My heater
Separate the case and trace out the wiring you are looking for an over heat limit switch. These are usually at the top of the case. You should also go over the element with a volt ohm meter make sure it is good, once you locate the thermal overload check it with the volt ohm meter it should read closed or dead short. If it reads open here is your culprit. It has been my observation that replacement parts can generally cost as much as replacing the entire heater. These I can pick up all day long for $19.00 at Home Depot the call them milk house heaters. Good luck with the repair.
Posted on Dec 29, 2010
Lakewood Model 792/A My heater has stopped working. The light indicates that it is receiving power. I checked the tip switch to see if stuck open. OK Next step please? Jeff
Dec 28, 2010 | Lakewood 792/JR Utility Heater
Where can I get a replacement thermostat for a Lakewood 792/JR space heater?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Nov 06, 2010 | Lakewood 792/JR Utility Heater
What to do if my lakewood 729 jr utility heater wont come on it on ly glows
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
Apr 09, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792 will not work
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792/AA Fan works and pushes warm air, but element/coils never heat up where heater actually gets hot.
Jan 13, 2010 | Lakewood 792/c Utility Heater
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
Dec 24, 2009 | Lakewood 792/JR Utility Heater
The fan is "sticking" before firing up. How do you correct the problem? Thanks for the help!
These motors normally use a sintered-bronze, graphite embedded bearing. They are normally pretty reliable but they can get clogged with a combination of graphite and contaminants from the air.
I would first try getting some WD-40 or other penetrating lubricant on the motor shafts if you can see them. It would work best if the fan was running if you can safely get some spray onto the shafts' ends.
BTW, WD-40 is not a lubricant and evaporates fairly quickly so isn't good for sewing machines for example. A resin-free light oil such as 3-in-1 is much better; it doesn't evaporate fast or leave sticky residue when it gets old.
Nov 29, 2009 | Lakewood 792/JR Utility Heater
Apr 14, 2007 | Lakewood 792/JR Utility Heater
Heating & Cooling Logo
26 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
