Question about Building Materials
I have a craftsman 41A4315-7d garage door opener and the light does not work although the bulb is good. Any suggestions? There is no information in the manual.
  • 10,045 Answers
There is a timer and relay that operates the bulb. One or both may be the problem
Posted on Dec 06, 2016
I am having a problem with my Craftsman 1/2 HP garage door opener 139-53910. My light bulb does not come on when the garage door is opened or closed as it should. I don't have a manual. Is there a...
Make sure the bulb is good. Unplug the opener and remove the bulb. Use a small screwdriver to pry out on the center contact in the light socket. Replace the bulb and plug in the opener.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 hp professional, all functions work except for lights, i have unplugged and replugged in, bulbs are new, contacts good. Any suggestions?
Unplug the opener and remove the bulb. Using a small screwdriver pull out on the center contact in the socket. Replace the bulb and plug in the opener.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2 horsepower garage door opener, both lights do not work. Changed bulbs, checked bulbs, both are good.
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light socket.
Apr 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Light will not function. Replaced light bulb but
Unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Mar 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Crafstman garage opener is melting my light bulbs!
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens and closes,light bulbs have been changed, light does not come on when door opens and closes
Unplug the unit and remove the light bulbs. Using a small screwdriver pull out on the center contact in the light bulb socket.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door light...
Some of the newer light bulbs do not work well. Unplug the unit and look in the actual socket. There is a copper lead, pull it up a little and try it. If not then you can replace the sockets themselves. Although it may be the logic board too. Make sure and get a surge protector on this nit 900 joules or higher. Thanks BB
Apr 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light does not come on when I open/close door, not the bulb
Good Morning:
I also substituted Floescent Bulbs for the standard bulbs. The bulbs would not light up although the relay was working. It seemed that the Florescent bulbs had a somewhat shorter neck. What I did was unplug the drive system from the outlet and then bend the metal connector in the socket so that it would come out further towards the opening of the socket. I then repluged the drive. The Floercent bulbs now have contact and are working perfectly. Simple problem with a simple solution.
Sandman
Oct 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
256 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
