Question about Cameras
Why do I need to reinsert SD card?
After inserting SD card I get message: please remove SD card and insert again. This message comes up every time I reinsert.
  • kakima Dec 05, 2016
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model camera? What capacity SD card?
    Top Expert:
  • Cameras Master
  • 78,936 Answers
Try another SD card, the one you have may be defective.
Posted on Dec 05, 2016
After inserting sd card, I get message that I need to insert again
it might be its not in the right way up.
or it may be that its not connecting on the little pins that are inside it.
Dec 05, 2016 | Cameras
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Nov 03, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
Phone keeps rebooting
Its simple: if rebooting occurs, just remove SD card and once booted, reinsert SD card.
Or, taking out the SIM, turn on without, turn off, and then restarting with SIM inserted again.
Apr 08, 2010 | O2 Samsung SGH-E250 Cellular Phone
Gphone Error
Maybe you can try to reset the phone back to factory settings (you'll lose all your data!!): 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Dec 01, 2008 | Google Android
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
How to hard reset the htc 710
to hard reset the htc s 710....................
1) switch off the phone first,
2) again switch it on....and as soon as the green led starts blinking (indication of phone coming to life) immedietly press and hold both the soft keys at a time, and follow the instruction given on u r phone screen. :)
Jul 09, 2008 | HTC S710 Smartphone
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
