Question about Food Mixers
The part that holds the mixing tools comes down too far and hits the bottom of mixing bowl
SOURCE: the attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Posted on Feb 12, 2009
hslincoln
  • 235 Answers
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
  • 4 Answers
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Posted on Jan 03, 2010
Testimonial: "Thank you for your post. I will check out the suggestionsl"
  • 130 Answers
SOURCE: Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Posted on Apr 08, 2010
SOURCE: kitchen aid mixer leans forward
Is this for a "tilt neck model? If so, the manual suggests that there is a small screw in between the base stand and the "neck" of the mixer. You should be able to screw it in or out to adjust it. Good luck!
Posted on Oct 28, 2010
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
The head of the mixer is vibrating (shaking) a lot when mixing. It does this so much that I feel as though I need to hold onto it when it's mixing. If I turn it on without the bowl and just run the...
I am sure you are locking the tilt head in the down position when your using it right? If so then check to see if the beaters are hitting the bottom of the bowl. If they are then there is an adustment screw that sets the height of the head in the down position.
Jan 01, 2011 | KitchenAid Classic Stand Mixer
My beater, dough hook, and wire whip all hit the bottom of the mixing bowl. I have been told that I can adjust them. Can you tell me how? Thank you
On the tilt head models there is a "Stop screw" that adjusts how far down the head goes. I just can't remember if it's in the head or base. I use the other model that lifts the bowl.
Dec 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I cannot raise the bowl enough for the batter to fully mix. There is always flour etc. left on the bottom of the bowl. The only way is to stand there and hold the bowl up and tilt it around..Which in my...
There's an adjustment screw as shown in the picture.
http://www.fixya.com/uploads/images/07F1BE1.jpg
Screwing this screw clockwise will raise up the bowl so the mixer paddle reaches closer to the bottom. Don't go too far, the paddle will start hitting the bowl.
May 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Mixing blade gets hung up at same spot on each turn
Hi SUSAN. From the symptoms you describe, it sounds like your mixer has a ‘Bowl to Beater Clearance’ issue. That should be pretty simple to fix. But even before we go there, check to make sure your mixing bowl is seating properly in the Bowl Support yolk and ‘snaps’ into place against the Bowl Spring Latch. My wife’s had that happen to her a few times. She thought the bowl was seated tightly, but it wasn’t and she experienced the same problem as you.
If your bowl is seating properly, the next thing to look at is your Beater to Bowl Clearance. The instructions are located in your Owners Instructions manual that came with your mixer. If your lacking one, you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KT2651 )and select the last file listed that appear under Owners Manuals (44): KT2651XWW3.pdf (2974.69 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 10 and you will find the instructions for adjusting the mixer head height.
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 19, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
KitchenAid model KB26G1XGN. The planetary gear appears to be falling out. The mixer blades were hitting the bowl before I had the bowl in the locked position. I got the top of the gear box off but can't...
Hi TJEWKES67. Before you tear into the ‘guts’ of your mixer any further, I’d like you to make a simple check the vertical play of the planetary. Locate where the planetary comes out of your mixer’s head, and place your left index finger on the edge of the planetary (rest your nail edge of the mixer head). With your right hand, push the planetary straight up (like you were trying to push it through the top of your mixer) until it stops, then let go. How much vertical movement did your index finger feel as you did this? Your planetary shouldn’t rise vertically more than a 1/16 of an inch, or less. If that’s the case, relax, your planetary is not coming out of your mixer, but just normal play within the transmission, and perfectly OK.
Before linking the beater to bowl clearance with the planetary gear ‘falling’, it would be much easier to first check the adjustment screw on the back of the pedestal to ensure that is properly adjusted. You don’t say how hold your mixer is, but I assume it is out of warranty.
Do you still have your Instructions & Recipe Manual for your mixer? If not, you can easily download a PDF version of it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KB26G1XN, and select the file that appear under Owners Manuals: KB26G1XGR5.pdf (2974.69 KB) and save it to your PC. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance, which I have extracted for you below:
See second comment...
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 12, 2009 | Food Mixers
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Nov 21, 2009 | KitchenAid Food Mixers
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Mar 20, 2009 | KitchenAid Artisan Series Tilt-Head Stand...
The head, on which the mixer is attached, is dipping down too low
HI. You may have asked your question in the wrong mixer category. The following link describes the Kitchenaid mixer at this heading. If this is not your mixer, try again. If this solution has assisted you, please rate it. Good luck! ricardok45 http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212054.pdf
Mar 12, 2009 | KitchenAid KHM5TB Classic Plus Hand Mixer
Food Mixers Logo
48 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
